alfred998
Simple Queue
Thu Aug 01, 2019 2:23 pm
I am trying to configure bandwidth limits, but smth isn't working
[admin@Mikrotik] > queue simple print
 0    ;;; Test
      name="T-test" target=192.168.1.36/32 parent=none packet-marks="" priority=8/8
      queue=default-small/default-small limit-at=0/0 max-limit=2M/512k burst-limit=0/0 burst-threshold=0/0
      burst-time=0s/0s bucket-size=0.1/0.1
 1    ;;; Test
      name="A-test" target=192.168.1.10/32 parent=none packet-marks="" priority=8/8
      queue=default-small/default-small limit-at=0/0 max-limit=512k/512k burst-limit=0/0
      burst-threshold=0/0 burst-time=0s/0s bucket-size=0.1/0.1
Then speedtest results still show the available maximum of 20/20M.
This are my firewall rules
[admin@Mikrotik] > ip firewall filter print
 0  D ;;; special dummy rule to show fasttrack counters
      chain=forward action=passthrough
 1    ;;; defconf: accept established,related,untracked
      chain=input action=accept connection-state=established,related,untracked log=no log-prefix=""
 2    ;;; defconf: drop invalid
      chain=input action=drop connection-state=invalid log=no log-prefix=""
 3    ;;; defconf: accept ICMP
      chain=input action=accept protocol=icmp log=no log-prefix=""
 4    ;;; defconf: drop all not coming from LAN
      chain=input action=drop in-interface-list=!LAN log=no log-prefix=""
 5    ;;; defconf: accept in ipsec policy
      chain=forward action=accept log=no log-prefix="" ipsec-policy=in,ipsec
 6    ;;; defconf: accept out ipsec policy
      chain=forward action=accept log=no log-prefix="" ipsec-policy=out,ipsec
 7    ;;; defconf: fasttrack
      chain=forward action=fasttrack-connection connection-state=established,related log=no log-prefix=""
 8    ;;; defconf: accept established,related, untracked
      chain=forward action=accept connection-state=established,related,untracked log=no log-prefix=""
 9    ;;; defconf: drop invalid
      chain=forward action=drop connection-state=invalid log=no log-prefix=""
10    ;;; defconf:  drop all from WAN not DSTNATed
      chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface-list=WAN log=no log-prefix=""
Am I missing smth ?
alfred998
Re: Simple Queue
Thu Aug 01, 2019 5:29 pm
Disabling fasttrack enabled made the queues effective:
7 X  ;;; defconf: fasttrack
I also should have mentioned that while doing speed tests at 20/20M, the bandwidth reported at queue for that specific IP was well below that. It seems this firewall rule somehow hided the real bandwidth on the IP.
Can anyone suggest a way to modify it instead of disabling ?
sebastia
Re: Simple Queue
Thu Aug 01, 2019 11:24 pm
See https://wiki.mikrotik.com/wiki/Manual:IP/Fasttrack
Fasttrack bypasses among other things, simple queues. But you could enable (=> flag) connections for fasttrack selectively. These will then bypass mangling as well. Total output can then be controlled by Queue Tree attached to outgoing interface. On that tree all fast-track-ed traffic will be "no-mark"-ed.
Users browsing this forum: sutrus, YaCy [Bot] and 45 guests
