rexilafa
Routing between bridged interfaces and a port
Fri Aug 02, 2019 6:06 pm
Hi! Needing a little help with setting up a router.
I have a mikrotik with a bridge on ports eth1, eth2 and eth3. On eth4 I have a PC connected that I want to be able to see all subnets (there are several in 192.168.0.0/16).
I have to add an ip for each subnet? (192.168.10.0, 192.168.20.0, etc) or there is a simpler way to do it?
The router IP on eth4 is 192.168.5.3 and the PC is 192.168.5.88.
Thanks!
mkx
Re: Routing between bridged interfaces and a port  [SOLVED]
Fri Aug 02, 2019 7:39 pm
Router needs IP address for each subnet it should be routing to/from.
Read up some IP routing basics ... when you do, don't skip the part with multiple routers in same network, this is the part where fun begins.
BR,
Metod
Users browsing this forum: No registered users and 31 guests
