naiyuan
Please help!!!!
Mon Aug 05, 2019 10:57 am
Today I am playing arround with Mikrotik router.
I saw the netwatch function.
Set every 10 seconds will ping a certain ip address.
The timeout is 20 seconds and will reboot.
Now, my router keeps restarting every 20 second there is no time for me to connect.
Please help me out of this!!!
Guntis
Re: Please help!!!!
Mon Aug 05, 2019 11:42 am
If the device has serial port, connect via that and after boot up paste this command in "/tool netwatch set [f] disabled=yes".
If you know the IP, you could try connecting host with that IP to the device, so ping would be successful, then you can disable rule afterwards.
Last option is to reset configuration.
cdiedrich
Forum Veteran
Forum Veteran
Re: Please help!!!!
Mon Aug 05, 2019 11:49 am
If your router has a serial console, you might get lucky with access from there and probably a script logging you in and disabling your netwatch item. That shouldn't take longer than two seconds.
Good luck!
-Chris
Christopher Diedrich
MTCNA, MTCUME, MTCWE
Basel, Switzerland
Bremen, Germany
There are 10 types of people: Those who understand binary and those who don't.
There are two types of people: Those who can extrapolate from incomplete data
naiyuan
Re: Please help!!!!
Mon Aug 05, 2019 1:33 pm
My Router is hEX PoE model. Is it applicable for solution 1?
Jotne
Re: Netwatch Reboot, need help
Mon Aug 05, 2019 1:56 pm
@naiyuan
Edit you first post an change Please help to some better.
How to use Splunk to monitor your MikroTik Router(s)
MikroTik->Splunk
Guntis
Re: Please help!!!!
Mon Aug 05, 2019 2:15 pm
If it's hEX POE, then first solution is not applicable as it doesn't have serial port.
Now you could do as cdiedrich said, and make a script that would log you in and disable Netwatch. Or you can try adding host with that IP. If neither of these is an option, then you have to reset the device.
Users browsing this forum: UnknownUsername and 26 guests
