Ameeno
VPN -> Lan Devices.
Thu Aug 08, 2019 12:04 pm
Hello All,
The VPN feature on the mikrotik hapac2 (dual home ap) gives vpn connected devices an IP in 192.168.89.2-254 range.
But the LAN devices at home is given the 192.168.88.10-254 range.
When i connect to vpn from outside my home, I cannot see items in the 192.168.88.1-254 range.
I think this is for security.
how can i fix this so i can connect to my lan devices from outside my home via VPN?
Ameeno
Re: VPN -> Lan Devices.
Sun Aug 11, 2019 11:52 am
I am bumping this as no reply!! :(
CZFan
Sun Aug 11, 2019 3:29 pm
It sounds like a routing problem, so either the vpn client does not know where to send packets for dst 192.168.88.0/x or internal devices does not know where to send these back to, doubt it is the latter though as they should have a default gateway if they access the internet.
Make sure you have a route on the VPN client to dst via vpn interface by either enabling "Use default gateway on remote network" if it is a Windows client, or adding routes manually
MTCNA, MTCTCE, MTCRE & MTCINE
Users browsing this forum: No registered users and 29 guests
