yacsap
disabling system -> package
Thu Aug 08, 2019 12:12 pm
Hi guys,
I have a question with system -> packages here.
Let's say I have configured something on /ip hotspot
Certainly there's configuration there.
If I go to system -> packages, disabled hotspot package and then reboot the router.
I cannot find the /ip hotspot config anymore
my quesions are:
1. does that mean my /ip hotspot config is removed from the router due to the hotspot package absence?
2. and if I reinstall the hotspot package, will my /ip hotspot config comes back?
[ IMikroTik ] >
yacsap
Re: disabling system -> package
Sun Aug 11, 2019 12:23 pm
bump.. anyone?
[ IMikroTik ] >
Sob
Re: disabling system -> package  [SOLVED]
Sun Aug 11, 2019 7:20 pm
Very quick test with PPP package says that config for disabled package is not lost and comes back when re-enabled. You can enable your hotspot package and see if it works there too.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply. Not intended as incentive for masochists.
yacsap
Fri Aug 16, 2019 11:47 am
Thank you for your quick test and answer. Cheers
[ IMikroTik ] >
Users browsing this forum: No registered users and 22 guests
