mikusk
wifi speed - 2 clients only
Thu Aug 08, 2019 8:39 pm
I have hAP lite where ether3 is connected to computer with samba share when I connect second computer to ether2 and try copy there is almost cable speed close to 100 Mbps.
I configured WIFI to allow maximum MCS7 - which is 65 / 72 MBps - 1 stream only
ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7
ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7
When I connect 1 client mobil or PC all looks good PC is constantly on 72 Mbps and mobil bouncing between 72 and 65 and real transfer speed was around 40 Mbps for Mobil and 60 Mbps for Notebook
Mobil - https://drive.google.com/file/d/1uXWJur ... sp=sharing
Notebook - https://drive.google.com/file/d/1TEiQft ... sp=sharing
Then I tried both mobile + notebook at the same time. I was awaiting than total speed will be 65 + 65 or 72 + 72 as hAP lite has 2 streams and real transfer speed will be close to 100 Mbps, but real speed was even worse 40 - 50 Mbps so it looks like 25 per client :-(
Both clients - https://drive.google.com/file/d/1X5cx6I ... sp=sharing
am I doing something wrong or is this normal ? I know that hAP lite is quite cheap but WIFI specification is 2 streams which is 144 Mbps for 20MHz I was awaiting that I can achieve something close to ethernet speed when 2 clients are connected to WiFi and each using just one stream ... I am on very clear 6 channel.
My config:
add admin-mac=74:4D:28:0F:CF:64 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-g/n basic-rates-a/g=12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-b="" disabled=no distance=\
    indoors frequency=2437 ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 mode=ap-bridge rate-set=configured ssid=\
    MikroTik-0FCF68 supported-rates-a/g=12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps supported-rates-b="" wireless-protocol=802.11 wps-mode=\
    disabled
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
add action=drop chain=forward comment="defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new \
    in-interface-list=WAN
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/tool mac-server
/tool mac-server mac-winbox
Thanks for any help explanation ..
MK
2frogs
Long time Member
Long time Member
Re: wifi speed - 2 clients only
Thu Aug 08, 2019 9:10 pm
What you are seeing is normal. The data rate is the combined theoretically possible rate for upload and download. Since the AP and Client can only send or receive and do so to a single device at a time it will half the data rate. And as you noticed, if you connect a second device and try to download/upload at same time, it gets halved again. The more streams the device is capable the higher the over all throughput, but your throughput will still be about half the data rate and divided between each active user.
mikusk
Thu Aug 08, 2019 11:43 pm
Thanks for explanation. I was thinking that If I have 2 spatial streams there will be one for each client 144 / 2 = 72.
It looks like 2nd spatial stream is not used at all :-(
May be that spatial stream can be used only towards one clients ...
In laptop there is Intel AC 7260 which is 2x2 so It should connect with 144
I will change my settings to allow use 2 spatial streams and will see if I got better results.
Thanks and regards,
MK
Sent from my SM-J530F using Tapatalk
Users browsing this forum: ErfanDL, pe1chl and 40 guests
