mailalert
Port isolating RB951G-2HnD
Mon Aug 12, 2019 8:33 pm
I have RB951G-2HnD and I'd like to isolate port, but have no luck and dont know why. Here is my configuration (what I've changed in default conf):
/interface bridge settings
set use-ip-firewall=yes
/ip firewall address-list
add address=192.168.88.10-192.168.88.255 list=block
add action=reject chain=forward dst-address-list=block reject-with=\
icmp-network-unreachable src-address-list=block
but I still can ping computers, so what's wrong?!
ps: I've used this tutorial> https://www.youtube.com/watch?v=UsgJFhkHB9g
Link100
Re: Port isolating RB951G-2HnD  [SOLVED]
Mon Aug 12, 2019 9:38 pm
Bridge->Ports
and then select the port/etherX where the filter should be applied and disable Hardware Offload.
Works?
mailalert
Mon Aug 12, 2019 10:07 pm
yeah! looks like working, thx!
but it is possible to configure one port (e.g. 2) for access all over network?
Link100
Mon Aug 12, 2019 11:09 pm
Then you simply leave Hardware Offload enabled for Port 2.
mailalert
Tue Aug 13, 2019 9:08 am
- I've did, but it didnt work .. but I will try again, thx!
Users browsing this forum: No registered users and 26 guests
