microtec
VPN
Mon Aug 12, 2019 10:16 pm
Hi, I have a PPTP VPN configured on my mikrotik router, all works fine and I can do ping to all the PC's except for one elastix server, if I do the ping on the mikrotik console I have response but if I do ping on a remote PC conected to the VPN I don't. The firewall on elastix server is disabled, I can conect to the VPN on a remote PC and enter to the router with winbox and then open the console and do ping to the elastix server and that works, but for example if I do ping on a remote PC conected to the VPN in a CMD console over windows I do not have response.
Steveocee
Re: VPN
Tue Aug 13, 2019 5:05 pm
You are on a different network so cannot natively reach the "LAN". Try creating a NAT rule from your VPN IP range as the traffic is from the WAN to the router and won't naturally go into your LAN.
Steve "Steveocee" Carter
PC Gamer, Airsofter, MikroTik Nerd
My Website - My MikroTik Tutorials
microtec
Re: VPN
Sat Aug 17, 2019 4:40 pm
Could you please help me creating that nat rule? The local ip on the vpn is 10.0.0.1 and the remote ip range is 10.0.0.2-10.0.0.20. The router network is 192.168.0.1/24. I want to reach 192.168.0.252. Thanks!
Steveocee
Re: VPN
Tue Aug 20, 2019 7:24 am
Something along this kind of line should do what you need
/ip firewall nat add chain=srcnat src-address=10.0.0.2-10.0.0.20 dst-address=192.168.0.252 action=masquerade comment="VPN clients to LAN"
microtec
Re: VPN
Tue Aug 20, 2019 9:18 pm
That worked perfectly!! Thanks!! =D
Users browsing this forum: No registered users and 23 guests
