Monkz
VLAN on WAN(Ether1) port
Wed Aug 14, 2019 7:28 pm
Hello! Please, help me with such configuration as you can see on attachment.
This is simplified config, after that i want to add a vpn server (with separate dhcp address pool) to access internal (192.168.200.0/24) lan.
What i need:
1) WAN (Eher1) port should be with Vlanid 20 and with ip 192.168.100.22 (my isp have 1:1 nat to this ip)
2) Eher2 port should have 192.168.200.2 ip to access internal network (dhcp server for 192.168.200.128/25 (yes /25) network we have on another router).
I tried to create this config using mikrotik default config adding VLAN to interfaces, but without luck. I stuck on assigning this VLAN to Eher1 interface.
Sob
Re: VLAN on WAN(Ether1) port
Thu Aug 15, 2019 3:55 am
- add vlan interface on ether1, name it as you want, give it id 20
- add address 192.168.100.22/xx on your new vlan interface (xx must be correct mask, you should have that from ISP)
- add default route with correct gateway (probably some 192.168.100.x, it's also part of info from ISP)
- if you use default config, add your new vlan interface to WAN interface list
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply.
Users browsing this forum: Google [Bot] and 23 guests
