srsipjf
Simple NAT between networks
Tue Aug 20, 2019 3:13 pm
Dear friends.
I have a v6.44.3 RouterBOARD 750G r3, configured as below:
Comment; Address; Network; Interface
Managing; 192.168.4.12/24; 192.168.4.0; ether3
ExternalLink; 192.168.1.1/24; 192.168.1.0; ether1
Office1; 192.168.17.1/24; 192.168.17.0; ether4
Office2; 192.168.16.1/24; 192.168.16.0; ether2
(Is this information enough?)
There are some users on Office1 and Office2.
Office1: 192.168.16.4 (host1); 192.168.16.48 (host2)...
Office2: 192.168.17.111 (shared printer); 192.168.17.44 (host17); 192.168.17.48 (host47-boss); 192.168.17.13 (guests)...
Office1 has a shared/lan printer: 192.168.17.111
We need that some Office2 user reaches the 192.168.17.111 printer.
It's possible to allow Office2 users to use the Office1's printer?
I've tried adding a static entry on ARP list as 192.168.16.111 and creating an NAT to redirect any access from 192.168.16.111 to 192.168.17.111 but didn't work.
Could'you help me?
Thanks!
anav
Re: Simple NAT between networks
Tue Aug 20, 2019 4:51 pm
I would think you would only need a firewall rule one way (forward chain) (subnet of users to specific IP of lan printer).
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
sebastia
Tue Aug 20, 2019 10:17 pm
start with posting your config
anav
Wed Aug 21, 2019 5:25 pm
Hey thats my line ;-)
/export hide-sensitive file=yourconfigaug21
AlainCasault
Trainer
Trainer
Wed Aug 21, 2019 5:31 pm
Hello
If all of this is on the same router, why would you need anything firewall wise to make it work?
Ali subnets are reachable by default unless you have something blocking traffic.
So yes, as suggested, post your config please
Regards,
Sent from my cell phone. Sorry for the errors.
___________________________
Alain Casault, Eng.
If I helped you, let me know!
Steveocee
Thu Aug 22, 2019 6:22 pm
Not needed. Default action is to allow anyway.
@OP Can you ping the printer from the "other" office? If all computers are using the MT as the gateway the default action should be "is the IP on my LAN? >no< Then go to the gateway" at this point the MT should be routing you to the printer.
Steve "Steveocee" Carter
PC Gamer, Airsofter, MikroTik Nerd
My Website - My MikroTik Tutorials
Users browsing this forum: No registered users and 16 guests
