SpongeB0B
Unstopable DSTNAT
Wed Aug 21, 2019 5:56 pm
Hi everyone,
Few days ago I put in place a /ip firewall nat (dstnat) in order to reach a local hosted WP.
So that dstnat was working. but I encounter problem witrh the WP itself (or might be the router finally)
See: https://wordpress.org/support/topic/no- ... -from-www/
Here my "dstnat" (numer 3 how is now disabled)
3 X chain=dstnat action=dst-nat to-addresses=192.168.x.y to-ports=xxx protocol=tcp in-interface-list=WAN dst-port=yyyyy log=yes log-prefix="thething"
But what I don't understand now that this dstnat is disabled, www browser still are redirected to yyyyy port !!!
I have done the following to try to get ride of the problem
  • tried on several computer
  • restarted the router and computers
  • I tried in the browser https://192.168.x.y:xxx (so the correct final destination port) and I'm anyway redirected to YYYYY the income port ! WTF.. did yo think it could be the WP ?
That redirection is still effectif and she defeitenly should not ! She is desactived and it should be only apply from WAN connection .. any ideas ??
Device: Hex: RB750Gr3
ingdaka
Re: Unstopable DSTNAT
Wed Aug 21, 2019 6:00 pm
Go to terminal type export and paste the result here!
Ilir Daka
Electronic & Network Engineer
E-mail: ilirdaka@live.com
Mob: +355692982151
WhatsApp: +355692982151
Mikrotik Official Consultant
CCNA | Fortinet NSE3 | MTCRE | MTCSE
SpongeB0B
Wed Aug 21, 2019 6:27 pm
# aug/21/2019 17:07:40 by RouterOS 6.40.9
# software id = D4LD-IJ8C
# model = RB750Gr3
# serial number = xxxxxxxxxxxxx
set [ find default-name=ether2 ] name=ether2-master
set [ find default-name=ether3 ] master-port=ether2-master
set [ find default-name=ether4 ] master-port=ether2-master
set [ find default-name=ether5 ] master-port=ether2-master
/ip neighbor discovery
set ether1 discover=no
set ether2-master discover=no
set ether3 discover=no
set ether4 discover=no
set ether5 discover=no
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip dhcp-server option
add code=6 name=loop_DNS1 value="'127.0.0.1'"
/ip hotspot profile
add name=dhcp ranges=192.168.XX.xx-192.168.xx.xx
add address-pool=dhcp disabled=no interface=ether2-master lease-time=23h59m59s name=defconf
/system logging action
add disk-file-count=5 disk-file-name="flash\\xxx" disk-lines-per-file=200 disk-stop-on-full=yes name=xxx target=disk
add disk-file-count=5 disk-file-name="flash\\xxx" disk-lines-per-file=250 disk-stop-on-full=yes name=xxx target=disk
add disk-file-count=5 disk-file-name="flash\\xxx" disk-lines-per-file=250 name=xxx target=disk
add comment=defconf interface=ether2-master list=LAN
add address=192.168.xx.1/26 comment=defconf interface=ether2-master network=192.168.xx.0
add address=192.168.0.2/24 interface=ether1 network=192.168.0.0
/ip cloud
set update-time=no
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid interface=ether1 use-peer-dns=no use-peer-ntp=no
/ip dhcp-server lease
add address=192.168.xx.2 always-broadcast=yes comment=xxx lease-time=12h mac-address=XXXXXXXXXX server=defconf
add address=192.168.xx.3 always-broadcast=yes comment=xxx lease-time=12h mac-address=XXXXXXXXXXX server=defconf
add address=192.168.xx.51 mac-address=XXXXXXXXXXXXXXX server=defconf
add address=192.168.xx.4 lease-time=23h59m59s mac-address=XXXXXXXXXXXXXX server=defconf
add address=192.168.xx.6 lease-time=23h59m59s mac-address=XXXXXXXXXXX server=defconf
add address=192.168.xx.5 mac-address=XXXXXXXXXXXXXXX server=defconf
add address=192.168.xx.30 mac-address=XXXXXXXXXXXXXXX server=defconf
add address=192.168.xx.31 mac-address=XXXXXXXXXXXXXXX server=defconf
add address=192.168.xx.52 dhcp-option=loop_DNS1 mac-address=XXXXXXXXXXXXXXX server=defconf
add address=192.168.xx.0/26 comment=defconf dns-server=xxxxxxxxxxxxx gateway=192.168.xx.1 netmask=26
set allow-remote-requests=yes servers=xxxxxxxxxxxxx
/ip dns static
add address=192.168.88.1 name=XXXXXX
add action=accept chain=input comment="defconf: accept established,related" connection-state=established,related
add action=accept chain=forward dst-port=xxx in-interface-list=LAN log=yes log-prefix=xxx: protocol=tcp src-address=192.168.xx.52
add action=drop chain=forward in-interface-list=LAN log=yes log-prefix=xxx: src-address=192.168.xx.52
add action=drop chain=forward connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=accept chain=input dst-port=80 in-interface-list=LAN protocol=tcp
add action=accept chain=input disabled=yes dst-port=53 in-interface-list=LAN protocol=udp
add action=drop chain=input in-interface-list=LAN
add action=dst-nat chain=dstnat dst-port=xxxxxxxxxxxxx in-interface-list=WAN protocol=udp to-addresses=192.168.xx.2 to-ports=xxxxxxxxxxxxx
add action=dst-nat chain=dstnat comment="WP" disabled=yes dst-port=XXXXXXXXXXXXXXX in-interface-list=WAN log=yes log-prefix=WP protocol=tcp to-addresses=192.168.xx.30 to-ports=XXXXXXXXXXXXXXX
add action=dst-nat chain=dstnat disabled=yes dst-port=XXXXXXXXXXXXXXX in-interface-list=WAN log=yes protocol=tcp to-addresses=192.168.xx.31 to-ports=XXXXXXXXXXXXXXX
add action=dst-nat chain=dstnat disabled=yes dst-port=XXXXXXXXXXXXXXX in-interface-list=WAN log=yes log-prefix=xxx: protocol=tcp to-addresses=192.168.xx.xx
add action=dst-nat chain=dstnat disabled=yes dst-port=XXXXXXXXXXXXXXX in-interface-list=WAN log=yes log-prefix=xxxxxxxxxxxxx protocol=tcp to-addresses=XXXXXXXXXXXXXXX
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
set udplite disabled=yes
set dccp disabled=yes
set sctp disabled=yes
add distance=1 gateway=192.168.0.1
/ip service
set telnet disabled=yes
set ssh disabled=yes
set api disabled=yes
set winbox disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=XXXXXXXXXXXXXXX
/system identity
set name=XXXXXX
/system logging
XXXXXXXXXXXXXXX
/system ntp client
set enabled=yes server-dns-names=xxxxxxxxxxxxx
/tool bandwidth-server
set enabled=no
/tool graphing interface
add allow-address=192.168.xx.0/26
/tool graphing resource
/tool mac-server
add disabled=yes interface=ether2-master
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
SpongeB0B
Wed Aug 21, 2019 6:56 pm
Damn 😠 ! it's the router !
I just connected directly to the machine who host the WordPress. and it work , no redirection...
Any ideas ? before I trow that piece of #@#*! in the trash ?
msatter
Wed Aug 21, 2019 7:17 pm
That router is perfectly fine.
In the NAT rule to wich ports do you translate. You need port 80 and 443 and I leave that empty and filter on the incoming side.
Two RB760iGS (hEX S) in series. One does PPPoE and both do IKEv2.
Running:
RouterOS 6.46Beta / Winbox 3.19 / MikroTik APP 1.3.2
Having an Android device, use https://github.com/M66B/NetGuard/releases (no root required)
SpongeB0B
Wed Aug 21, 2019 7:42 pm
@msatter,
The router is not ok,
Within the LAN side the router is not set to redirect anything (only if coming from WAN)
furthermore the dstnat rules is disabled ->
and more the redirection point me the the outside port ! (dst-port and not the correct one ~"transfer to" ) so no I don't think the router behave like it should,
Sob
Wed Aug 21, 2019 8:22 pm
The router is fine, is doesn't contain any kind of creative module that would do anything not told it to do by config. Disabled rules are not active, period.
Your linked post at WP suggests that it's something with WP config. Check http requests in browser's developer console (for example in Firefox it's Ctrl+Shift+E), try to open your website, examine headers and I'm sure you'll find some redirection there.
Btw, I understand being a little paranoid, hiding public addresses and other possibly sensitive stuff (that's probably good idea). But hiding private addresses and ports doesn't make sense. And don't be fooled by the name "private", it just means "non-public", i.e. that the same 192.168.xx.30 is duplicated in million LANs all over the world.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply.
SpongeB0B
Wed Aug 21, 2019 8:49 pm
Thank @Sob,
So how can you explain when I plug my self (RJ45) directly to the host computer it's work (same IP)
but when passing by the router not !
So I don't think it is WordPress or Browser issue but router,
:D , damn that why I bought it, I was thinking it had a sort of A.I inside :P, beside the joke, what it does it's related to my input ! because the browser get redirected to the WLAN incoming port , so it's not random. but what I don't get it's that rules is disabled and anyway the redirections still occur event after rebooted everything ! (my self included :P )
Sob
Wed Aug 21, 2019 9:08 pm
Http is more complex. If you enter https://192.168.1.77 in browser and then you try https://exemple.com:54321 (taken from your WP post), for web server it's not the same, those are requests for two distinct virtual hosts. And what happens depends on server or web application. As I wrote, check in browser what exactly happens.
SpongeB0B
Thu Aug 22, 2019 12:20 am
Thank sob, but actually I try the opposite.
So first from outside (wan side) this redirection was working (almost as I had the bug with the image not showing) but still trying to figure where is the problem coming with that.
the redirection was outside :54321 to inside :443 so the port for the HTTPS, and for the server this is transparent.
From the inside it's was working also without changing the port, just like this https://192.168.0.X
but now when I disable the redirection, again within the Lan, when I enter https://192.168.0.X i'm redirected to https://192.168.0.X:54321 ! (not even 433 ! wtf)
So I don't think it's the Wordpress server how do that ( I didn't setup nothing for redirection there) nor the browser(s)..
and when I directly physically connect to the WP server (who keep is dhcp IP for while) I'm not redirected and it's working obviously.
So it's not the router the problem ???????
Sob
Thu Aug 22, 2019 12:59 am
After you're redirected, do you actually see https://192.168.0.X:54321 in browser's address bar, including the port? If you do, it's definitely not done by router. And again, if you check server requests in browser developer console, you'd see the redirection sent by server on http level there.
SpongeB0B
Sun Aug 25, 2019 10:22 am
Hi Sob, yes I do see https://192.168.0.X:54321 in browser's address bar... damn so it's the server ! damn why is doing this ? and why he is not doing it when connect directly to it.. so weird.
Sob
Sun Aug 25, 2019 7:15 pm
You need to check and possibly adjust server config. As I wrote, server can see difference between direct connection in LAN and connection from internet, and can behave diferently for them.
If the webserver is some pre-made appliance and you didn't install and configure it yourself, it's probably some option where you set the address for website (the one that should be publicly visible), and server redirects other requests there. Try to look for something like that.
SpongeB0B
Wed Sep 04, 2019 9:04 pm
Hi everyone,
Little update,
I've spend few hours to test everything's, I tried also with different routers (DD-wrt, OpenWRT, Stock D-Link and Stock Asus)
So I don't experience this Unstoppable DSTNAT anymore, it might be the WP server itself, for what I read and experienced changing the domain or IP of a WordPress server can sometime a pain in the *ss
For example on one of my iteration of this WP server, after successfully changed the IP the wordpress pages content are mix (meaning some element point to the new ip and other keep the old one.. so it's a mess..)
To good thing is while I was testing different router I clearly notice how good is my little RB750Gr3 compare to the other router.
example who shocked me : D-link : cannot enter a NTP server but instead need to choose between 2 NTP server owned by D-Link, or worst impossible to disable IPv6 WTF.
martinclaro
Thu Sep 05, 2019 2:37 am
Good to hear you resolved the issue.
For future reference, the traffic between 2 IP addresses belonging to the same bridge and same subnet does NOT go through the firewall as it is a Layer-3 firewall (unless you have enabled the use-ip-firewall option under /interface bridge settings).
Martín C. @ TopHost Soluciones
MTCNA | MTCTCE
Sob
Thu Sep 05, 2019 3:15 am
Oh yeah, RouterOS is great. Regular home routers support only few predefined scenarios, and when you need anything else, you're out of luck. With RouterOS, you can configure almost anything. But it's also easier to make mistakes. Great freedom, great responsibility. And IPv6 is cool, don't disable that.
Steveocee
Fri Sep 06, 2019 12:15 pm
@OP ^^^ this. Which is likely why none of your routers were giving the desired outcome as well.
Steve "Steveocee" Carter
PC Gamer, Airsofter, MikroTik Nerd
My Website - My MikroTik Tutorials
Users browsing this forum: No registered users and 13 guests
