punx
RB4011iGS with more subnets
Sun Aug 25, 2019 10:25 pm
I have RB4011iGS
- ether1 is wan
- ether2 is 192.168.10.1/24, DHCP - connected to PC1 (Windows, IP 192.168.10.254)
- ether10 is 192.168.20.1/24, DHCP - connected to PC2 (Windows, IP 192.168.20.254)
Internet works on PC1 and PC2.
PC1 can not ping PC2
PC2 can not ping PC1
From RB I can not ping PC1, but I can ping PC2.
How can I reconfigurate so that PC1 can ping PC2 and vice versa?
Why can RB ping PC2,and not PC1?
On different RB (RB751U) I have default configuration with ether ports that have different subnets and RB can ping all the clients. Also, clients form different subnets can ping each other as long as this filter rule is not applied:
ip firewall filter add chain=forward action=drop src-address=192.168.10.0/24 dst-addresss=192.168.20.0/24
ip firewall filter add chain=forward action=drop src-address=192.168.20.0/24 dst-addresss=192.168.10.0/24
Why doesn't RB4011iGS work like RB751U and how can it be set so that it does?
RB4011iGS (RouterOS 6.45.3) conf:
set 0 default-vlan-id=0
set 1 default-vlan-id=0
set 2 default-vlan-id=0
set 3 default-vlan-id=0
set 4 default-vlan-id=0
set 5 default-vlan-id=0
set 6 default-vlan-id=0
set 7 default-vlan-id=0
set 8 default-vlan-id=0
set 9 default-vlan-id=0
set 10 default-vlan-id=0
set 11 default-vlan-id=0
add include=dynamic name=WAN
add include=dynamic name=lan_hotspot
add include=dynamic name=LAN
add name=dhcp_hotspot ranges=192.168.10.2-192.168.10.254
add name=dhcp_lan ranges=192.168.20.2-192.168.20.254
add address-pool=dhcp_hotspot disabled=no interface=ether2 name=dhcp_hotspot
add address-pool=dhcp_lan disabled=no interface=ether10 name=dhcp_lan
add interface=ether1 list=WAN
add interface=ether2 list=lan_hotspot
add interface=ether10 list=LAN
add address=192.168.10.1/24 interface=ether2 network=192.168.10.0
add address=192.168.20.1/24 interface=ether10 network=192.168.20.0
add address=192.168.2.22/24 interface=ether1 network=192.168.2.0
add address=192.168.10.0/24 dns-server=8.8.8.8 gateway=192.168.10.1
add address=192.168.20.0/24 dns-server=8.8.8.8 gateway=192.168.20.1
set servers=8.8.8.8
    established,related,untracked
    invalid
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
add distance=1 gateway=192.168.2.1
mkx
Re: RB4011iGS with more subnets
Sun Aug 25, 2019 10:47 pm
As somebody replied in some thread: the magic ball department is using another forum. If you want to get some useful input here, start by posting complete configuration - you can get it running /export hide-sensitive in command window.
BR,
Metod
punx
Mon Aug 26, 2019 12:02 am
Sorry on mistake....complete configuration with changed IPs:
add admin-mac=74:4D:28:87:E1:32 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] comment="dol"
set [ find default-name=ether2 ] comment="HS"
set [ find default-name=ether3 ] comment=Bridge
set [ find default-name=sfp-sfpplus1 ] disabled=yes
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=10.8.0.101-10.8.0.199
add name=dhcp_HS ranges=192.168.101.2-192.168.101.254
add address-pool=dhcp disabled=no interface=bridge name=dhcp_LAN
add address-pool=dhcp_HS interface=ether2 lease-time=30m name=dhcp_HS
/queue simple
add dst=ether1 limit-at=20M/20M max-limit=20M/20M name=HotSpot target=ether2
add dst=ether1 limit-at=30M/30M max-limit=30M/30M name=LAN target=bridge
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add address=10.8.0.253/24 comment=defconf interface=bridge network=10.8.0.0
add address=192.168.101.2/24 interface=ether1 network=192.168.101.0
add address=192.168.101.1/24 disabled=yes interface=ether2 network=192.168.101.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=30m
add address=10.8.0.0/24 comment=defconf gateway=10.8.0.253 netmask=24
add address=192.168.101.0/24 gateway=192.168.101.1 netmask=24
set allow-remote-requests=yes servers=195.29.247.161,195.29.247.162
/ip dns static
add address=10.8.0.253 name=router.lan
    invalid
    in-interface-list=!LAN
    connection-state=established,related disabled=yes
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
    invalid
add action=drop chain=forward comment="defconf:  drop all from WAN not DSTNATed" \
    connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
    out,none out-interface-list=WAN
add distance=1 gateway=192.168.101.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set winbox port=8291
set api-ssl disabled=yes
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/system identity
set name=RB_1
/tool mac-server
/tool mac-server mac-winbox
mkx
Mon Aug 26, 2019 8:26 am
The shown configuration doesn't correspond to how you described the config:
The config doesn't show any IP config on ether2 - there's a disabled entry for 192.168.101.1/24 which by itself doesn't allow communication with PC1.
ether10 is member of bridge, which has set IP address 10.8.0.253/24 - which doesn't allow communication with PC2.
So either you obfuscated posted config just too much (thus muddying the view in crystal ball beyond usability) or you need to fix the IP setup on your router to match designed LAN layout. Or there's another router in the play which stirs the setup even more.
BTW, if you did obfuscate IP addresses: you only have to obfuscate public IP address, nobody is able to connect to your private (LAN) IP addresses directly so no point in obfuscating that.
The firewall rule set is default and most of rules deal with WAN connectivity. There's nothing which would break connections between ether2 (not accounted in any of interface lists) and ether10 (member of bridge, which is member of LAN interface list). On the other hand, the last rule in chain=input drops all connections to the router itself not coming from LAN, which also disallows any connection from ether2 to router including to DNS service (but that one is not set-up in dhcp-server network section, so it's fine ... if you intended to make it so).
BR,
Metod
punx
Tue Aug 27, 2019 10:06 pm
New configuration, without any Firewall Filter Rules (only for this test).
ether1 - DHCP client, wan
PC1 have IP 192.168.5.254 and is connect to ether2
PC2 have IP 192.168.10.254 and is connect to ethr10
PC1 can ping PC2, PC2 can ping PC1.
How can config RB that block traffic between subnets in both directions?
How can config RB that block traffic between subnets only in one direction (PC1 can ping PC2 but PC2 can not ping PC1)?
Thank you and sorry on my mistakes.
RB configuration:
# aug/27/2019 20:42:49 by RouterOS 6.45.3
# software id = EUPX-DS2T
# model = RB4011iGS+
add name=dhcp_pool0 ranges=192.168.5.2-192.168.5.254
add name=dhcp_pool1 ranges=192.168.10.2-192.168.10.254
add address-pool=dhcp_pool0 disabled=no interface=ether2 lease-time=1h name=\
    dhcp1
add address-pool=dhcp_pool1 disabled=no interface=ether10 lease-time=1h name=\
    dhcp2
add address=192.168.5.1/24 interface=ether2 network=192.168.5.0
add address=192.168.10.1/24 interface=ether10 network=192.168.10.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether1
add address=192.168.5.0/24 gateway=192.168.5.1
add address=192.168.10.0/24 gateway=192.168.10.1
mkx
Wed Aug 28, 2019 8:46 am
If the RB configuration you posted is complete, then firewall is non-existing (and the device is thus open for any attacks). I strongly suggest to start again, this time select reset with factory defaults to have a very sensible firewall rules enabled.
Anyway, if we start from empty firewall, you can block connections between the subnets this way:
blocking all traffic in both directions:
/ip firewall raw
# note that raw rules work on raw packets so src-address and dst-address strictly filter every single packet without taking context into account
add action=drop chain=prerouting src-address=192.168.5.0/24 dst-address=192.168.10.0/24
add action=drop chain=prerouting dst-address=192.168.5.0/24 src-address=192.168.10.0/24
If you only want to block certain type of traffic, then you can add additional selectors to the above rules (e.g. add protocol=tcp dst-port=80 to block only HTTP). In that case you might need to add more rules to block everything you want to block ... in this case it might be better to explicitly allow permissible traffic (by adding rules with action=accept) and block everything else using the shown rules. Mind that rule order is important, they are executed from top to bottom.
If you want to bock traffic only when connections get initiated from one side, then you have to use different rules (which include connection tracking):
# the first rule is there by default
# block connections from PC2 only ...
add action=drop chain=forward src-address=192.168.10.0/24 dst-address=192.168.5.0/24
# connections from PC1 are not blocked and are thus allowed. The other direction is allowed due to top most rule
BR,
Metod
punx
Wed Aug 28, 2019 12:17 pm
RB configuration is complete, firewall is non-existing only for this tests.
I need config which will for sure block all traffic between the subnets (on one subnet is sensitive data and I do not want someone from other subnet to reach them).
Thank you!
martinclaro
Wed Aug 28, 2019 6:13 pm
You can start by removing the ether10 port from bridge, or assign the IP address to the bridge.
Martín C. @ TopHost Soluciones
MTCNA | MTCTCE
punx
Wed Aug 28, 2019 8:50 pm
From post #5, ether10 not in bridge.
martinclaro
Wed Aug 28, 2019 9:01 pm
Ok, can you provide the output of the following commands?
/ip arp print
/ip address print
/ip route print
Just obfuscate the public IP addresses only.
MTCNA | MTCTCE
punx
Wed Aug 28, 2019 10:04 pm
    dhcp1
    dhcp2
/ip dhcp-client
/ip arp print
 #    ADDRESS         MAC-ADDRESS       INTERFACE
 0 DC 192.168.5.254   00:25:22:AF:F0:30 ether2
 1 DC 192.168.10.254  A0:2B:B8:34:DB:7A ether10
/ip address print
 #   ADDRESS            NETWORK         INTERFACE
 0   192.168.5.1/24     192.168.5.0     ether2
 1   192.168.10.1/24    192.168.10.0    ether10
/ip route print
 0 ADC  192.168.5.0/24     192.168.5.1     ether2                    0
 1  DC  192.168.10.0/24    192.168.10.1    ether10                 255
punx
Wed Aug 28, 2019 10:08 pm
Now I apply code from mkx and all works fine.
Thank you mkx and thank you martinclaro! :-)
Users browsing this forum: No registered users and 18 guests
