martintokman
Cant block google on chrome
Fri Aug 30, 2019 9:27 pm
Hi, i am beginer on microtik, i am practicing with firewall rules and try to block all internet access from the lan, i have created a firewall rule that drops for the forward chain on tcp port 80. also i have created another rule but for 443 port.
I use brave and chrome browsers, using brave the rule is working fine and i cant get anything from internet, but in chrome is different because i can browse to google, i can get into the google's page and do a search if i want, then when i try to get any result the router blocks the connection, but it doesnt work on the google's page.
Maybe i am doing something wrong, could you please give me a clue?
Kind regards
msatter
Re: Cant block google on chrome
Fri Aug 30, 2019 10:26 pm
UDP 443 block.
Two RB760iGS (hEX S) in series. One does PPPoE and both do IKEv2.
Running:
RouterOS 6.46Beta / Winbox 3.19 / MikroTik APP 1.3.2
Having an Android device, use https://github.com/M66B/NetGuard/releases (no root required)
Users browsing this forum: No registered users and 14 guests
