TheFox21
RB3011UiAS-RM is not showing USB Stick anymore
Sat Aug 31, 2019 1:20 pm
since I upgraded my RB3011UiAS-RM to RouterOS v6.45.5 it does not recognize the SanDisk Ultra Fit 128 GB anymore. Before I upgraded everything worked fine.
Then I downgraded to RouterOS v6.45.3 because this was the previous version where everthing worked. I applied the old configuration from the backup. But even back on the old packages version and firmware version it does not show the USB stick in the Disks list anymore.
I tried the USB stick on other computers and it's working fine. I also tried several different USB devices on the Routerboard but with no success.
What I'm doing wrong?
mkx
Re: RB3011UiAS-RM is not showing USB Stick anymore
Sat Aug 31, 2019 2:55 pm
Which way the RB is not recognising the stick? Does it show under /system resources usb? Any pluged device should show there even if device isn't supported in ROS whatsoever.
If it does but doesn't show as disk, then you'll have to reinitialize it ... if the USB device doesn't show under USB devices, then it might be that there's some hardware dammage?
BR,
Metod
TheFox21
Sat Aug 31, 2019 4:03 pm
[admin@r3] > /system resource usb print
 # DEVICE VENDOR                         NAME                       SPEED
 0 1-0    Linux 3.3.5 xhci-hcd           xHCI Host Controller       480
 1 2-0    Linux 3.3.5 xhci-hcd           xHCI Host Controller       5000
 2 3-0    Linux 3.3.5 xhci-hcd           xHCI Host Controller       480
 3 4-0    Linux 3.3.5 xhci-hcd           xHCI Host Controller       5000
I'm not sure how the list looks like when the USB stick is working. This is list is without any devices plugged in.
Before I upgraded I always saw the USB stick in
[admin@r3] > /disk print
 # NAME                  LABEL                TYPE    DISK                      FREE       SIZE
Even if it was not initialized. This Routerboard is a few weeks old. I bought it in mid July.
mkx
Sat Aug 31, 2019 4:30 pm
Nope, your RB doesn't seem to notice the USB device. Here's how it looks on my RBD52G when USB flash disk is plugged in:
[fu@bar] /system resource usb> print
 0 1-0    Linux 3.3.5 xhci-hcd-ipq40xx      xHCI Host Controller     480
 1 2-0    Linux 3.3.5 xhci-hcd-ipq40xx      xHCI Host Controller     5000
 2 1-1    Generic                           Mass Storage             480
Just for fun of it, I plugged a Huawei smart phone to one of my RB951Gs:
[fu@baz] /system resource usb print
 0 1-0    Linux 3.3.5 ehci_hcd       RB400 EHCI           480
 1 1-1    HUAWEI                     ANE-LX1              480
and phone didn't really export any of its USB services, it was set to use USB for charging only.
BR,
Metod
TheFox21
Sat Aug 31, 2019 6:09 pm
I factory reset the Router and reapplied the configuration from backup but still not working. Seems like the USB is gone with the upgrade.
Edit: the hEX Routerboard is recognizing the same USB stick.
Users browsing this forum: No registered users and 16 guests
