kiutsitsu
Forwar VPN through specific Dynamic Wan
Sat Aug 31, 2019 10:03 pm
Good evening,
As you read from the title i need help on that. I have one Mikrotik with two pppoe clients (Wan1 , Wan2) which are dynamic. I want the 1st Wan to be used for work and the 2nd Wan i want to be used for remote backup through VPN (L2tp) in another location again with Mikrotik and again with dynamic pppoe wan. If i take the dynamic ip of the remote location and put it directly in routes (dst addr = ip, Gateway = Wan2) of the 1st Mikrotik then it works fine. But Ip changes every day so i cant work with that.
Any ideas cause i'm out of them...
Thank you
Sob
Re: Forwar VPN through specific Dynamic Wan
Sun Sep 01, 2019 12:02 am
PPPoE can run scripts when it connects or disconnects, you can configure routes from there.
Manual (look for on-up and on-down): https://wiki.mikrotik.com/wiki/Manual:P ... r_Profiles
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply.
kiutsitsu
Mon Sep 02, 2019 2:25 pm
Good evening
Thank you for the reply but i can't manage to understand your solution. Maybe i didnt explain correct.
Site1
Mikrotik
2 Wan (WAN1, WAN2) via PPPOE Client through internet provider that takes random ip from now and then (i want to use WAN2 for vpn)
Server
Site2
Mikrotik
1 Wan via PPPOE Client through internet provider that takes random ip from now and then
Nas
L2TP VPN
Site 1 L2tp Client via Mikrotik Cloud of site2 L2tp Server.
How can i use the pppoe Scipt for site 1 to renew route ip taken from Site 2?
Hope it is more clear now.
Thank you in advance
kiutsitsu
Mon Sep 02, 2019 4:42 pm
Ok i made a new profile for VPN and added this script on up and worked.
:log info "Starting VPN update"
:global RemoteIp [:resolve <<remote cloud>>]
:log info "New remote IP is $RemoteIp"
/ip route set 0 dst-address=$RemoteIp
Thank you
Sob
Re: Forwar VPN through specific Dynamic Wan  [SOLVED]
Mon Sep 02, 2019 8:04 pm
That's it. Only instead of using rule number directly, you may want to give the route some unique comment and use that to find it, i.e.:
/ip route set [/ip route find comment="my-route"] dst-address=$RemoteIp
That way it will work even if you make some changes in routes and this one will no longer be number 0.
kiutsitsu
Mon Sep 02, 2019 11:52 pm
You are the best. Thank you
Users browsing this forum: No registered users and 24 guests
