triki
Firewall
Mon Sep 02, 2019 12:39 pm
Hey.I wanna drop all input traffic from udp . but if i do that some staff will not work, so and i trying drop all traffic above 500 kbps Rx rate from udp, but cant do that.Ty.
Steveocee
Re: Firewall
Mon Sep 02, 2019 2:56 pm
Maybe post an export of your current firewall? It sounds like you don't have an accept established & related rule either.
Steve "Steveocee" Carter
PC Gamer, Airsofter, MikroTik Nerd
My Website - My MikroTik Tutorials
anav
Re: Firewall
Mon Sep 02, 2019 4:42 pm
The firewall in default settings is good to go.
Why do you want to add more rules. What is the requirement or what is the fear?
What are you trying to avoid??
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
MTUNA Certified, by the Ascerbic Llama!
triki
Re: Firewall
Mon Sep 02, 2019 5:39 pm
Hm some one ddosed me with udp flood . and if i block this manualy under attack ppl just littl lag and nothink more. but if i no block they dropped.
idk maybe i jsut need script like "if i have above 4k conections ip to my router > router will start block all udp" bad guy ddosed about 1-2 min with free "ip stress" site.
anyway i just dont wanna drop any players from game cus game can be more 2 hours.
Users browsing this forum: No registered users and 20 guests
