Mustava
Convert Wifi to Wired
Thu Sep 05, 2019 1:05 pm
Hello
I have a wifi network and want a device work as wireless bridge so i could join the device through wifi and convert it so i can provide other device with wired cables
what is the suitable device to do that
I'm new with the product and it'll be the first time to use it
mkx
Re: Convert Wifi to Wired
Thu Sep 05, 2019 3:30 pm
Any wireless-capable Routerboard device will do. But: wireless bridge generally only works if devices on both ends of wireless link are made by same vendor. The reason is that there is no standard way of creating truly transparent wireless bridge and vendors created own proprietary extensions to work around this limitation. Needless to say that these extensions are not compatible between vendors.
As we're on Mikrotik forum: use a pair of Routerboard devices and you'll be fine.
BR,
Metod
erlinden
Thu Sep 05, 2019 4:26 pm
I use my hAP AC Lite as travel router. Mostly using a wireless backhaul. Works perfectly, haven't had problems on connecting to any wireless network yet. So I fully disagree with @mkx (based on my experience).
First the problem, then the solution
CZFan
Thu Sep 05, 2019 8:34 pm
I suspect that is not the same thing what mkx is talking about, I suspect you are connecting as a wireless client, i.e. station and not "bridging" with wireless
MTCNA, MTCTCE, MTCRE & MTCINE
pe1chl
Thu Sep 05, 2019 9:28 pm
Indeed. It will work OK when you setup the AP as a client and do the normal NAT thing behind that, but when you configure it as a transperent bridge (i.e. your wired clients get their address from the existing wireless router's DHCP server) you will see interesting things happen. Certainly when there is more than one client on the wired side.
Users browsing this forum: No registered users and 22 guests
