i am using a dsl modem with a mikrotik router. The router establishes a pppoe connection. When powercycling router and modem at the same time the router boots faster while the modem is still syncing with the dslam. But the modem has a dhcp server and gives a local ip 192.168. to the mikrotik router (only for connecting to the webif of the modem) The Router sets its default gateway to this ip. Even if the router established the pppoe connection the default route is not set to wan IP.
To fix this i have to reboot the router while the modem is synced. Then the correct default route to wan ip is set.
How can i fix this, so that i can boot the router while the dsl modem is not synced?
BR
