MUM Europe 2020
jwrite2019
Configuration help. Is this possible?
Wed Sep 18, 2019 10:50 pm
I have a Mikrotik CRS305-1G-4S+IN and wondering if it's possible to have it setup like this diagram below.
I essentially want it to establish a pppoe connection for a pair of ports to a switch, as well as offer a connection for another router to establish its own pppoe (bridge, mirror?).
Any help would be greatly appreciated.
sebastia
Re: Configuration help. Is this possible?
Wed Sep 18, 2019 11:06 pm
Hi
While CRS305 technically can do what you propose, it's not meant to do that: it can do pppoe but not at speed, as it's not fast enough on cpu side.
jwrite2019
Thu Sep 19, 2019 4:19 am
What are the realistic capabilities of this device?
Is there a better device you recommend?
The speed from the provider is 1.75gbps
Thanks!
chechito
Thu Sep 19, 2019 7:11 am
bad idea
use CRS as Switch, the only purpose to do pppoe or any other Layer 3 configuration will be management purposes not for live traffic
jwrite2019
Wed Sep 25, 2019 12:35 pm
Ok. I appreciate the advice guys.
Thank you!
Users browsing this forum: SiB, youtube345 and 33 guests
