I am new to Mikrotik's world so I would like your help for my topic. I am trying to set a VPN network that can be accessible from outside.
I have followed some instructions and tutorials, and from my PC (in the network) I am able to connect to my VPN, but it seems that is not accessible from outside.
Please check my configuration below and let me know if i have done something wrong.
My network topology is the following:
I use a Netfaster IAD 2 modem/router to serve as a modem and a Mikrotik hAP lite as the main router.
Netfaster IAD 2 ip: 192.168.2.1
Mikrotik ip : 192.168.88.1
My PC 192.168.88.13
Code: Select all
# sep/19/2019 20:59:13 by RouterOS 6.45.5
# software id = JRKF-PBIQ
# model = RouterBOARD 941-2nD
add admin-mac=B8:69:F4:0E:74:D0 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether2 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether3 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether4 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 keepalive-timeout=disabled name=pppoe-out1 use-peer-dns=yes user=guest@adsl.gr
/interface pptp-server
add name=pptp-in1 user=ppp1
add comment=defconf name=WAN
add comment=defconf name=LAN
add authentication-types=wpa2-psk management-protection=allowed mode=dynamic-keys name=profile1 supplicant-identity=MikroTik
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce disabled=no distance=indoors frequency=auto mode=ap-bridge security-profile=profile1 ssid=HomeWifi wireless-protocol=802.11
add name=dhcp ranges=192.168.88.10-192.168.88.100
add name=dhcp_pool1 ranges=192.168.88.2-192.168.88.254
add name=VPNpool ranges=192.168.88.101-192.168.88.150
add address-pool=dhcp disabled=no interface=bridge name=defconf
/ppp profile
add bridge=bridge change-tcp-mss=yes dns-server=8.8.8.8,8.8.8.4 local-address=192.168.88.1 name=VPMprofile remote-address=VPNpool
/interface detect-internet
set internet-interface-list=all
/interface pptp-server server
set default-profile=VPMprofile enabled=yes
add address=192.168.88.1/24 comment=defconf interface=ether2 network=192.168.88.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=192.168.88.1 name=router.lan
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=accept chain=forward dst-port=1723 protocol=tcp
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none out-interface=pppoe-out1
add action=dst-nat chain=dstnat dst-address=5.54.215.246 dst-port=1723 protocol=tcp to-addresses=192.168.88.13 to-ports=1723
add distance=1 dst-address=192.168.2.10/32 gateway=ether1
/ppp secret
add name=ppp1 profile=VPMprofile service=pptp
/system clock
set time-zone-name=Europe/Athens
/tool mac-server
/tool mac-server mac-winbox
