MUM Europe 2020
s0ll3kr4m
Redirecting after connecting to the WiFi..
Fri Sep 27, 2019 9:16 pm
Hello!!
im using the hap lite router, and i created a hotspot
everything work just fine!
the problem is when im connected to the WiFi from an device, it does not redirect automatically to ask for user and login pass, u have to manually set it on the url to the specific dns name.
so is there a way that i can fix it?
thank you for any repsonse!!
zakynthoswifi
Re: Redirecting after connecting to the WiFi..
Sat Sep 28, 2019 5:52 pm
Under ip>dhcp server>networks did you specified dns servers?
For me that was the problem for some devices
Ilias Theodosis
Network & Security Engineer
Cisco CCNA,CCNP,CCIE
Network Solutions Ltd.
Zakynthos, Greece
s0ll3kr4m
Sat Sep 28, 2019 10:00 pm
Thank you for your answer!
in the network of the hotspot i did not set anything in dns servers, should i put something there, so the redirection would happen?
zakynthoswifi
Sun Sep 29, 2019 12:08 am
No,
under the section i told you only.
DNS under hotspot is to give to your hotspot a unique dns domain name (landing.myfasths.gr)
Ilias Theodosis
Zakynthos, Greece
s0ll3kr4m
Sun Sep 29, 2019 9:28 am
Yea I gave a dns hotspot.status but, when I'm connecting to the WiFi, the browser don't open automatically, or it doesn't go automatically to the hotspot.status, you have to type it manually.
That's my problem, I want it to happen automatically.
zakynthoswifi
Sun Sep 29, 2019 2:04 pm
please open terminal and type
/ip dhcp-server network print
and give us the output here
Ilias Theodosis
Zakynthos, Greece
s0ll3kr4m
Sun Sep 29, 2019 3:31 pm
im getting this
Flags: D - dynamic
 #   ADDRESS            GATEWAY         DNS-SERVER           WINS-SERVER     DO..
 0   ;;; defconf
     10.10.3.0/24       10.10.3.1
 1   ;;; hotspot network
     10.10.4.0/24       10.10.4.1
note:the subnet 10.10.4.0 is the hotspot
s0ll3kr4m
Sun Sep 29, 2019 4:45 pm
should i also include the /ip hotspot export here ?
s0ll3kr4m
Sun Sep 29, 2019 5:40 pm
heres the ip hotspot
# sep/29/2019 17:24:45 by RouterOS 6.45.6
# software id = 4L42-C3TX
# model = RB941-2nD
# serial number = A1C30A560349
/ip hotspot profile
set [ find default=yes ] hotspot-address=10.10.4.1 login-by=\
    http-chap,https,mac-cookie ssl-certificate=Hotspot
add dns-name=hot.spot hotspot-address=10.10.4.1 login-by=http-chap,mac-cookie \
    name=hsprof1 use-radius=yes
/ip hotspot
add address-pool=hs-pool-9 addresses-per-mac=1 disabled=no idle-timeout=none \
    interface=bridge-hotspot name=hotspot profile=hsprof1
/ip hotspot user
add name=admin password=xxxxxxxx
add comment="mark account" name=mark password=xxxxxxxx server=hotspot
add comment="welcome jimaras how are you \?" name=Jimaras password=\
    xxxxxxxxxx server=hotspot
add comment=welcome name=john password=xxxxxxxxxxxx server=hotspot
add comment="asus laptop" name=babas password=xxxxxxxxx server=hotspot
add name=Asus password=xxxxxxxxxxx server=hotspot
add name=laptopMark password=xxxxxxxxxxxx server=hotspot
s0ll3kr4m
Mon Sep 30, 2019 12:51 pm
this is my all configuration file
# sep/30/2019 12:41:41 by RouterOS 6.45.6
# model = RB941-2nD
add admin-mac=74:4D:28:40:EF:59 auto-mac=no comment=defconf name=bridge
add name=bridge-hotspot
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce \
    disabled=no distance=indoors frequency=auto mode=ap-bridge ssid=\
    "Hot Spot Nasa" wireless-protocol=802.11
set [ find default-name=ether1 ] advertise=\
    10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether2 ] advertise=\
set [ find default-name=ether3 ] advertise=\
set [ find default-name=ether4 ] advertise=\
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk eap-methods="" \
    supplicant-identity=MikroTik wpa-pre-shared-key=xxxxxxxxxxxx\
    wpa2-pre-shared-key=xxxxxxxxxx
add authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys name=profile \
    supplicant-identity=MikroTik wpa-pre-shared-key=xxxxxxxxxxxxx \
    wpa2-pre-shared-key=xxxxxxxxxxxxx
/ip hotspot profile
add name=dhcp ranges=10.10.3.2-10.10.3.253
add name=hs-pool-9 ranges=10.10.4.2-10.10.4.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add address-pool=hs-pool-9 disabled=no interface=bridge-hotspot lease-time=1h \
    name=dhcp1
/ip hotspot
add address-pool=hs-pool-9 addresses-per-mac=1 disabled=no interface=\
    bridge-hotspot name=hotspot1 profile=hsprof1
/interface bridge filter
# no interface
add action=drop chain=forward in-interface=*8
# no interface
add action=drop chain=forward out-interface=*8
add bridge=bridge-hotspot comment=defconf interface=wlan1
add bridge=bridge interface=*8
/interface wireless access-list
add ap-tx-limit=40000000
add address=10.10.3.1/24 comment=defconf interface=ether2 network=10.10.3.0
add address=192.168.1.2/24 interface=ether1 network=192.168.1.0
add address=10.10.4.1/24 interface=bridge-hotspot network=10.10.4.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid interface=ether1
add address=10.10.3.0/24 comment=defconf gateway=10.10.3.1 netmask=24
add address=10.10.4.0/24 comment="hotspot network" gateway=10.10.4.1
set allow-remote-requests=yes servers=1.1.1.1,1.0.0.1
/ip dns static
add address=10.10.3.1 name=router.lan
add action=passthrough chain=unused-hs-chain comment=\
    "place hotspot rules here" disabled=yes
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
add action=dst-nat chain=dstnat comment=OpenVPN dst-address=192.168.1.2 \
    dst-port=443 protocol=tcp to-addresses=10.10.3.231 to-ports=443
add action=masquerade chain=srcnat comment="masquerade hotspot network" \
    src-address=10.10.4.0/24
/ip hotspot user
add name=admin password=xxxxxxxxxxxxxxxx
add comment="mark account" name=mark password=xxxxxxxxxxxx server=hotspot1
    xxxxxxxxxxxxx server=hotspot1
add comment=welcome name=john password=xxxxxxxxxxxxxx server=hotspot1
add comment="asus laptop" name=babas password=xxxxxxxxxxx server=hotspot1
add name=Asus password=xxxxxxxxxxxx server=hotspot1
add name=laptopMark password=xxxxxxxxxxxxx server=hotspot1
add distance=1 gateway=192.168.1.254
add distance=1 dst-address=10.10.10.0/24 gateway=10.10.3.231
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/radius
add address=127.0.0.1 secret=xxxxxxxxxx service=hotspot
/radius incoming
set accept=yes
/system clock
set time-zone-name=Europe/Athens
/tool mac-server
/tool mac-server mac-winbox
zakynthoswifi
Mon Sep 30, 2019 3:32 pm
im getting this
Flags: D - dynamic
 0   ;;; defconf
Ok under this menu add the missing dns-server value with 10.10.4.1 as dns and you will be fine!
Ilias Theodosis
Zakynthos, Greece
s0ll3kr4m
Mon Sep 30, 2019 4:08 pm
still after adding that, the problem persists
flags: D - dynamic
 0   ;;; defconf
     10.10.4.0/24       10.10.4.1       10.10.4.1
when i open a http site it doesnt redirect to the login page.
s0ll3kr4m
Tue Oct 01, 2019 11:21 am
anyone?
please help i really want to solve this issue, it bothers me a lot.
s0ll3kr4m
Tue Oct 01, 2019 1:34 pm
i have done fresh install everything but still no redirection after entering an http site.
i want the user, when entering in SSID wifi , and accessing an http site to redirect him to the login page, so he will put the credentials.
right now they see the login page only if they put 10.10.4.1 or hot.spot in the address
here is the new config file :
# oct/01/2019 13:21:26 by RouterOS 6.45.6
# model = RB941-2nD
/interface wireless
set [ find default-name=wlan1 ] disabled=no mode=ap-bridge ssid=\
    "Hot spot Nasa"
/ip hotspot profile
add dns-name=hot.spot hotspot-address=10.10.4.1 login-by=http-chap name=\
add name=hs-pool-7 ranges=10.10.4.2-10.10.4.254
add address-pool=hs-pool-7 disabled=no interface=bridge-hotspot lease-time=1h \
    name=dhcp1
/ip hotspot
add address-pool=hs-pool-7 addresses-per-mac=1 disabled=no interface=\
add bridge=bridge-hotspot interface=wlan1
add address=192.168.1.2/24 comment="main subnet router/modem" interface=\
add address=10.10.3.1/24 comment=\
    "subnet 10.10.3.0 \E4\DF\EA\F4\F5\EF mikrotik" interface=ether2 network=\
    10.10.3.0
add address=10.10.4.1/24 comment="ip address assign to bridge" interface=\
add address=10.10.4.0/24 comment="hotspot network" dns-server=10.10.4.1 \
    gateway=10.10.4.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=10.10.4.1 name=hot.spot
add action=dst-nat chain=dstnat dst-port=443 in-interface=ether1 \
    in-interface-list=all protocol=tcp to-addresses=10.10.3.231 to-ports=443
/ip hotspot user
add distance=1 gateway=192.168.1.1
/ip ssh
/radius
add address=127.0.0.1 secret="\CE\E9\EC\E1\F1\E1\F35511" service=hotspot
/radius incoming
set accept=yes
/system clock
Users browsing this forum: MSN [Bot] and 20 guests
