abuumarselo
get Alert by email on new Device
Tue Nov 05, 2019 10:20 am
Hi
I need a script that send me an email whenever a new device is connected to my network ( Got a dynamic IP in dhcp leases ) ( LAN or WiFi)
note that all known devices has static IP given
cdiedrich
Forum Veteran
Forum Veteran
Re: get Alert by email on new Device
Tue Nov 05, 2019 10:29 am
You could trigger /tool e-mail from your dhcp server's lease-script
-Chris
Christopher Diedrich
MTCNA, MTCUME, MTCWE
Basel, Switzerland
Bremen, Germany
There are 10 types of people: Those who understand binary and those who don't.
There are two types of people: Those who can extrapolate from incomplete data
abuumarselo
Tue Nov 05, 2019 10:33 am
I've added the flowing script in dhcp server alerts but not working
:tool e-mail send to=email@example.com subject="Violation alert!!! New DHCP client in the network" body="MAC: $leaseActMAC,
please guide me
cdiedrich
Forum Veteran
Forum Veteran
Tue Nov 05, 2019 1:41 pm
Did you configure /tool e-mail before?
Like:
/tool e-mail
set address=mail.provider.com from=dhcpalerts@provider.com password=youremailpassword port=465 start-tls=tls-only user=dhcpalerts@provider.com
-Chris
Basel, Switzerland
Bremen, Germany
abuumarselo
Tue Nov 05, 2019 2:17 pm
yes
and I already have a scheduled script that emails me configuration backup every certain period of time
cdiedrich
Forum Veteran
Forum Veteran
Tue Nov 05, 2019 2:31 pm
Hmmm...
Turn on logging for topics e-mail,debug and trigger that command manually. Then you can see the whole smtp session in your log.
Maybe you find a hint on what's wrong there.
-Chris
Basel, Switzerland
Bremen, Germany
pe1chl
Tue Nov 05, 2019 2:32 pm
Your script has a syntax error, missing closing quote.
Test your script commands e.g. in a CLI window to see if they work.
abuumarselo
Tue Nov 05, 2019 2:54 pm
I've got this script from a search but also no email sent when a new device connected to network
I put it in dhcp server alert with default settings of new alert
:local recipient "someemail@soemserver.com"
/ip dhcp-server lease
:if ($leaseBound = 1) do={
	:do {
		:tool e-mail send to=$recipient subject="DHCP Address Alert [MAC: $leaseActMAC]" body="The following MAC address [$leaseActMAC] received an IP address [$leaseActIP] from the DHCP Server [$leaseServerName]"
		:log info "Sent DHCP alert for MAC $leaseActMAC"
	} on-error={:log error "Failed to send alert email to $recipient"}}
there is no log entry
I think the event didn't fire and the code never executed
pe1chl
Tue Nov 05, 2019 7:00 pm
Debugging MikroTik scripting (especially scripts executed on event) is very frustrating!
When there is the slightest syntax error in your script it will just do nothing and no error is logged.
Also, some syntax that you would think is valid in reality is not, e.g. for some complicated expressions.
That is why I recommend testing the script from CLI first.
Also be sure you fully understand the script permissions thing.
WeWiNet
Long time Member
Long time Member
Thu Nov 07, 2019 1:25 am
Would be interested in such a script as well! For me just logging with a custom text would be enough...
Keep us updated when you find the solution...
WeWiNet
MTCNA
I like a new challenge, I migrate to ROS7... :? no way, finally I stay with 6.48! I am NOT crazy :lol: !!!
RackKing
Re: get Alert by email on new Device  [SOLVED]
Thu Dec 05, 2019 3:58 am
	:do {
This should go in the script box of the dhcp-server you want it to run on - not in the alerts tab.
abuumarselo
Thu Dec 05, 2019 10:16 am
	:do {
thank you I think it is my mistake I'll try that and reply
abuumarselo
Thu Dec 05, 2019 10:55 am
now It worked fine
thanks for all help
abuumarselo
Thu Dec 05, 2019 11:36 am
a simple alteration to the script
the previous script sends an email when ever a new devices connected to router static or dynamic
in my situation I need to know only dynamic ones because the static ones in known to me
this modification sends only dynamic ip addresses
:local recipient "someemail@server.com"
:if (($leaseBound=1) && ([/ip dhcp-server lease find where dynamic mac-address=$leaseActMAC]!="")) do {
	:do {
abuumarselo
Wed Dec 25, 2019 11:47 am
Nice Addition to the script
add filter rule to block mac address from using internet
	:do {
               add chain=forward src-mac-address=$leaseActMAC action=drop
gotsprings
Thu Dec 26, 2019 3:26 pm
www.domotz.com
Email, alert on your phone, and log.
"It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
RackKing
Thu Dec 26, 2019 5:46 pm
Very nice - thank you.
	:do {
mozerd
Long time Member
Long time Member
Mon Dec 30, 2019 4:40 pm
	:do {
Very nice modification .... just to let you know that on my system this generates a syntax error in the following:
To correct the following change works:
&& ([/ip dhcp-server lease find where dynamic mac-address=$leaseActMAC]!="")) do= {
lsettembri
Mon Mar 02, 2020 8:06 pm
Anyone knows how to add the hostname to the email? Thanks!
hngjared
Thu Jun 11, 2020 11:03 pm
To add the hostname use $"lease-hostname"
kostmas
Sat Mar 27, 2021 3:19 pm
Anyone knows how to send email only if a new device connected.
I mean, if the "lease time" is not over yet, then don't send email
Users browsing this forum: Semrush [Bot] and 9 guests
