LonliLokli
Cannot redirect port to a specific ip
Thu Nov 07, 2019 7:07 pm
Maybe somebody can help me? Cannot redirect some ports to specific up (ports are 16881 and 26881), getting check that port is closed.
Here is the sample from configuration
https://pastebin.com/CnMH5FTE
mkx
Re: Cannot redirect port to a specific ip
Thu Nov 07, 2019 8:06 pm
Are sure it's NAT on your RB who's blocking? It could be your ISP as well ...
BR,
Metod
LonliLokli
Thu Nov 07, 2019 8:35 pm
I was trying to check with tool one of them and saw it on Tourch screen.
I am just not sure is it router or actual device (Synology NAS) issue.
AlainCasault
Trainer
Trainer
Thu Nov 07, 2019 8:45 pm
If you suspect Synology problem, test on the same LAN. If it doesn't work, then you found it.
I haven't read all of your export but make sure your firewall accepts the redirected traffic. I've seen many people think that a simple dst-nat is an implicit accept through the FW.
Cheers,
Sent from my cell phone. Sorry for the errors.
___________________________
Alain Casault, Eng.
If I helped you, let me know!
LonliLokli
Fri Nov 08, 2019 11:34 pm
Thank you, are you absolutely right! I determined with your proposal that it's my Synology fault, LAN did not pass port check. I was able to solve this issue with proper Docker ports configuration and careful reading of another service documentation.
Thank you again!
AlainCasault
Trainer
Trainer
Fri Nov 08, 2019 11:41 pm
Cool. Glad to be of help. :)
Alain Casault, Eng.
Users browsing this forum: No registered users and 48 guests
