jsbahnsen
RB705gr3 with ISP vlan
Fri Nov 08, 2019 4:17 pm
So for a while I have been trying to get my RB750gr3 to connect to the internet.
The end goal is to connect two hAP AC2's for wifi together with capsman for control.
Unfortunately, I have tried for several months to get the router to provide access to the internet. My ISP requires vlan 101 on the wan port.
By following the guide for simple router setup (first part of: https://wiki.mikrotik.com/wiki/Manual:S ... sMAN_setup) combined with this forum post (viewtopic.php?t=142965) see that my router acquires the IP provided by the ISP. However, internet is not accessible through the router.
I have a feeling that I am extremely close to a solution and I may just be missing a simple tick somewhere or maybe I have overlooked something else.
Any help would be highly appreciated!
Thank you
Jesper
(setup is pasted in below)
[admin@MikroTik] > /export hide-sensitive
# jan/05/1970 00:17:50 by RouterOS 6.45.7
# software id = 6NWI-A2L6
# model = RouterBOARD 750G r3
# serial number = 6F3806D44C57
add name=bridge1
/interface vlan
add interface=ether1 name=vlan101 vlan-id=101
add name=WAN
add name=LAN
/ip hotspot profile
add name=dhcp ranges=192.168.0.10-192.168.0.254
add address-pool=dhcp disabled=no interface=bridge1 name=dhcp1
add interface=ether1 list=WAN
add address=192.168.0.1/24 interface=ether2 network=192.168.0.0
/ip dhcp-client
add add-default-route=no dhcp-options=hostname,clientid disabled=no interface=vlan101 use-peer-dns=no use-peer-ntp=no
add address=192.168.1.0/24 dns-server=192.168.1.1 gateway=192.168.1.1 netmask=24
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
add disabled=yes distance=1 gateway=80.210.78.1
xvo
Long time Member
Long time Member
Re: RB705gr3 with ISP vlan  [SOLVED]
Fri Nov 08, 2019 4:34 pm
That is what is missing:
/interface list member add interface=vlan101 list=WAN
jsbahnsen
Fri Nov 08, 2019 5:33 pm
Thank you so much! I really appreciate your help.
I also found that "ip pool", "ip address" and "ip dhcp-server network" was mismaching.
I corrected this along with your sugestion. On my windows PC i get internet connection icon in the system tray (was not there before), however there is nothing loading in the browser.
anav
Fri Nov 08, 2019 5:44 pm
Is the routing disabled or enabled?
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
xvo
Long time Member
Long time Member
Fri Nov 08, 2019 5:46 pm
Check what DNS server your PC gets from your router.
jsbahnsen
Sun Nov 10, 2019 1:46 pm
Sorry for the delayed answer. I looked at the route list and in fact one of the entities was diabled (ip 0.0.0.0). I activated and [eureka!!!] everything seems to be working now.
Thank you both so much! I have literally spend days on this.
Users browsing this forum: No registered users and 25 guests
