Hello!!
I know this asked like thousand times, but I can't really find a proper way of doing it.
Let's say I want to port forward modern warfare 3 in mikrotik so the nat type would be opened.
Here are the ports 3074, 27014-27050 TCP
UDP 3074, 27014-27030.
What the proper command should I write in terminal.
Also when I'm connecting my PC straight to the modem/router the nat is opened.
It's moderate only if the pc is connected to the router mikrotik.
Thank you for any answer regarding to my problem!!
