MUM Europe 2020
Aroldo
Dual WAN without configuration
Thu Nov 28, 2019 7:38 pm
I'm new to RouterOS. I have a 5 port router connected to 2 modem from 2 different ISPs and a LAN.
I have eth3 and eth4 ports configured to be WAN and other ports are slave and part of the bridge (that is the LAN).
I know that i should configure PCC for load balancing and failover, fiddle around with mangle rules... but first, I'm asking myself what is happening right now, without any configuration. I see traffic in both connections... how is it working?
Sorry if this question is stupid, but I'm a noob...
Zacharias
Re: Dual WAN without configuration
Fri Nov 29, 2019 10:14 pm
Only one WAN is used...
Aroldo
Mon Dec 02, 2019 1:26 pm
Ok, thank you.
I see that all the traffic goes through eth4. eth3 has only little traffic, communications between the 2 routers, i think.
What makes the router choose eth4 instead of eth3?
Zacharias
Mon Dec 02, 2019 3:23 pm
Can i see a screenshot of your routing Table ?
Aroldo
Mon Dec 02, 2019 5:12 pm
This one?
Zacharias
Mon Dec 02, 2019 5:27 pm
Ok, i thought i would see an automatic ECMP applied, but no...
ingdaka
Tue Dec 03, 2019 10:47 pm
If there are no administrative distance set traffic goes from port 4 because has lowest IP Subnet 192.168.120.0/24 vs 192.168.121.0/24
If you want to set which of them should work you can remove add default route to NO in IP>DHCP Client and add them manually with different distance! Lowest distance win i this case! And to make this automatic failover set check gateway ping when add default gateway!
Ilir Daka
Electronic & Network Engineer
E-mail: ilirdaka@live.com
Mob: +355692982151
WhatsApp: +355692982151
Mikrotik Official Consultant
CCNA | Fortinet NSE3 | MTCRE | MTCSE
xvo
Long time Member
Long time Member
Tue Dec 03, 2019 10:54 pm
You don't really need to set "add default route" to no: DHCP-client (as well as PPPoE-client, L2TP-client, etc.) have "Default route distance" setting, so automatic route creation can still be used with needed distance.
Zacharias
Wed Dec 04, 2019 12:57 am
So an IP address with the same subnet prefix as an other one, /24 in this example, has greater priority if the IP address number is smaller than the other's one ? Any reference to back that up ?
Users browsing this forum: MSN [Bot] and 24 guests
