MUM Europe 2020
Zarch
Samsung M2026W printer - capsman - 4 way handshake failure
Fri Nov 29, 2019 6:50 pm
I have a Samsung M2026W printer that used to work fine on my old router before update to Mikrotik
I have one HP AC2 as my main router and then two HAP AC lite hanging off in a Capsman config.
I cannot get the wireless printer to register on the network.
16:25:04 caps,info 84:25:19:31:34:6F@wlan-downstairs-cap-2ghz connected, signal strength -56
16:25:04 caps,info 84:25:19:31:34:6F@wlan-downstairs-cap-2ghz disconnected, 4-way handshake failure
16:25:05 caps,info 84:25:19:31:34:6F@wlan-downstairs-cap-2ghz connected, signal strength -62
16:25:05 caps,info 84:25:19:31:34:6F@wlan-downstairs-cap-2ghz disconnected, 4-way handshake failure
16:25:07 caps,info 84:25:19:31:34:6F@wlan-downstairs-cap-2ghz connected, signal strength -60
16:25:07 caps,info 84:25:19:31:34:6F@wlan-downstairs-cap-2ghz disconnected, 4-way handshake failure
I tried all sorts.
Removed access lists (ie dont drop weak signals)
disabled all firewall rules
made various changes to the security of my capsman... adding/removing encryption and connection types
added and removed b/g/n network settings.
I'm at a loss really now. What constitutes a '4-way handshake failure'?
Any help or suggestions would be very much appreciated.
Thanks.
Zarch
Re: Samsung M2026W printer - capsman - 4 way handshake failure
Fri Nov 29, 2019 7:17 pm
To add, all three devices are at the latest stable; 6.45.7
Zacharias
Re: Samsung M2026W printer - capsman - 4 way handshake failure  [SOLVED]
Fri Nov 29, 2019 11:07 pm
Its because of the security configuration used.
Maybe the device does not support newer encryption algorithms...
What is the encryption you use ?
Zarch
Fri Nov 29, 2019 11:39 pm
Thank you for replying, think I might have sorted it.
I had both aes ccm and tkip set for both encryption and group encryption.
No matter what combination I set it always seemed to fail.
So I decided to totally remove encryption options which left the SSID 'open'.
But this allowed the registration to complete ok.
Now the printer has a DHCP IP i've put aes ccm encryption back on and its seems ok.
Will monitor.
Thanks again...... your hint really helped.
Zacharias
Sat Nov 30, 2019 1:21 pm
I ve seen that too with older devices... no matter what encryption you choose or what combination you make, every time it simply fails...
Users browsing this forum: No registered users and 23 guests
