MUM Europe 2020
TheFlash
RouterOS suddenly blocked at least one website
Sat Nov 30, 2019 9:32 am
Hi, i`m new to RouterOS and it seams that it blocked access to a website that i`m trying to connect, i do not see anything in logs but traceroute stops within the router
Zacharias
Re: RouterOS suddenly blocked at least one website
Sat Nov 30, 2019 1:46 pm
Is the default firewall used ?
If yes i dont think it blocked anything...
TheFlash
Sat Nov 30, 2019 5:40 pm
Yes, it`s the default firewall. If the firewall isn`t the issue than what`s wrong?
pe1chl
Sat Nov 30, 2019 6:28 pm
You will have to show your config /export for people on the forum to help you.
TheFlash
Sun Dec 01, 2019 5:21 pm
This is my config, something not too complicated, very basic .
Thank You!
Zacharias
Sun Dec 01, 2019 5:43 pm
First, update your ROS version...
Also, no need to have winbox port open to public. Use VPN....
Other than that, i dont see any reason why your router would block any sites...
If you connect a pc directly to your ISP, can you access those sites ?
pe1chl
Sun Dec 01, 2019 6:18 pm
Indeed!
Steps to perform:
- update RouterOS to latest stable version
- reset settings to default
- re-add the particular features you require
TheFlash
Mon Dec 02, 2019 11:19 am
I'll make an update and reset the router. This is a secodary router. It isn't connected to the ISP. If i want to reach the site from in front of mikrotik everything is ok. Traceroute shows that packet never leave mikrotik router
pe1chl
Mon Dec 02, 2019 11:37 am
We will see what happens after you update. If possible use netinstall to install the newest versions, so it is certain there are not any trojans left.
Zacharias
Mon Dec 02, 2019 3:11 pm
Agree...
TheFlash
Mon Dec 02, 2019 8:01 pm
i kinda solved the problem... partially my fault. When i tried to verify from in front of mikrotik router i tryed directly from pfsense firewall that is connected directly to isp. I pinged the ip of the website (from lan interface and from wan interface) and worked. The mikrotik router fooled me thinking that the problem is from him because when traceroute from behind the mikrotik the packets never traveled to the next hop (pfsense). The problem was that PFSense has a blacklist on firewall with hijacked websites and seems that the site i was trying to reach got on that list.
Thank You guys!
P.S.: How can i mark the topic as SOLVED?
Zacharias
Mon Dec 02, 2019 8:11 pm
Tick button on the post that was the solution to the problem...
pe1chl
Mon Dec 02, 2019 8:31 pm
It is still advisable to update you MikroTik but as it was found (likely) not to be infected you can do it from the device itself (system->packages->check for updates).
It is also still advisable to do a reset to defaults after that, and add what you need (you can take your save .rsc file as a guide for that)
And, keep your RouterOS recent, update it at least every couple of months.
Nollitik
Sat Dec 07, 2019 9:00 pm
It's great to see another with pfSense and Mikrotik combo network. Usually, a firewall never suddenly blocks websites though.
Users browsing this forum: No registered users and 22 guests
