MUM Europe 2020
shibs
Do I have my firewall rules and VLANs correct?
Sat Jan 04, 2020 7:21 pm
My router (hAP AC2) is set up but restored to default incase something is quite wrong.
VLAN10: Main (it will get a rule for intervlan access)
VLAN20: Another VLAN setup, nothing yet, maybe Chromecast and related devices here or in iot
VLAN30: No initiating connections out, smart devices that seem to sniff network/upload, no WAN/intervlan
VLAN40: Regular iot, no intervlan
VLAN50: Guest network, no intervlan, default forwarding off
VLAN99: management vlan
Right now, management vlan has ether4 and wifi, wifi will be removed once everything is set up, it was good incase access was lost via ethernet. All vlans can access the router right now to change settings.
Ether5-trunk goes to a L2 switch. Everything might get moved to it for a router on a stick.
My config:
#RouterOS 6.46.1
# software id =
# model = RBD52G-5HacD2HnD
# serial number =
add name=bridge protocol-mode=none vlan-filtering=yes
set [ find default-name=ether1 ] name=ether1-WAN
set [ find default-name=ether4 ] name=ether4-mgmt
set [ find default-name=ether5 ] name=ether5-trunk
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    disabled=no distance=indoors frequency=auto installation=indoor mode=\
    ap-bridge name=wlan-2ghz ssid=main wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto \
    installation=indoor mode=ap-bridge name=wlan-5ghz ssid=main \
/interface vlan
add interface=bridge name=home-vlan vlan-id=10
add interface=bridge name=additional-vlan vlan-id=20
add interface=bridge name=block-vlan vlan-id=30
add interface=bridge name=iot-vlan vlan-id=40
add interface=bridge name=guest-vlan vlan-id=50
add interface=bridge name=mgmt-vlan vlan-id=99
add name=WAN
add name=VLAN
add name=mgmt
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=\
    dynamic-keys supplicant-identity=MikroTik
add authentication-types=wpa2-psk eap-methods="" mode=dynamic-keys name=guest \
add authentication-types=wpa2-psk eap-methods="" mode=dynamic-keys name=iot \
add authentication-types=wpa2-psk eap-methods="" mode=dynamic-keys name=mgmt \
add authentication-types=wpa2-psk eap-methods="" mode=dynamic-keys name=block \
/interface wireless
add disabled=no hide-ssid=yes keepalive-frames=disabled mac-address=\
    xx:xx:xx:xx:xx:xx master-interface=wlan-2ghz multicast-buffering=disabled \
    name=wlan-block security-profile=block ssid=block wds-cost-range=0 \
    wds-default-cost=0 wps-mode=disabled
add default-forwarding=no disabled=no keepalive-frames=disabled mac-address=\
    xx:xx:xx:xx:xx:xx master-interface=wlan-5ghz multicast-buffering=disabled \
    name=wlan-guest security-profile=guest ssid=guest wds-cost-range=0 \
    name=wlan-iot security-profile=iot ssid=iot wds-cost-range=0 \
add disabled=no hide-ssid=yes mac-address=xx:xx:xx:xx:xx:xx master-interface=\
    wlan-5ghz name=wlan-mgmt security-profile=mgmt ssid=mgmt
/ip hotspot profile
add name=home-pool ranges=10.0.10.10-10.0.10.150
add name=guest-pool ranges=10.0.50.10-10.0.50.150
add name=iot-pool ranges=10.0.40.10-10.0.40.150
add name=mgmt-pool ranges=192.168.99.10-192.168.99.150
add name=blocked-pool ranges=10.0.30.10-10.0.30.150
add name=additional-pool ranges=10.0.20.10-10.0.20.150
add address-pool=home-pool disabled=no interface=home-vlan name=home-dhcp
add address-pool=guest-pool disabled=no interface=guest-vlan name=guest-dhcp
add address-pool=iot-pool disabled=no interface=iot-vlan name=iot-dhcp
add address-pool=additional-pool disabled=no interface=additional-vlan name=\
    additional-dhcp
add address-pool=mgmt-pool disabled=no interface=mgmt-vlan name=mgmt-vlan
add address-pool=blocked-pool disabled=no interface=block-vlan name=\
    blocked-dhcp
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged \
    ingress-filtering=yes interface=ether2 pvid=40
    ingress-filtering=yes interface=ether3 pvid=10
    ingress-filtering=yes interface=ether4-mgmt pvid=99
add bridge=bridge frame-types=admit-only-vlan-tagged ingress-filtering=yes \
    interface=ether5-trunk
    ingress-filtering=yes interface=wlan-2ghz pvid=10
    ingress-filtering=yes interface=wlan-5ghz pvid=10
    ingress-filtering=yes interface=wlan-guest pvid=50
    ingress-filtering=yes interface=wlan-iot pvid=40
    ingress-filtering=yes interface=wlan-mgmt pvid=99
    ingress-filtering=yes interface=wlan-block pvid=30
/interface bridge vlan
add bridge=bridge tagged=bridge,ether5-trunk untagged=\
    ether3,ether4-mgmt,wlan-2ghz,wlan-5ghz vlan-ids=10
add bridge=bridge tagged=bridge,ether5-trunk vlan-ids=20
add bridge=bridge tagged=bridge untagged=wlan-guest vlan-ids=50
add bridge=bridge tagged=bridge,ether5-trunk untagged=wlan-iot,ether2 \
    vlan-ids=40
add bridge=bridge tagged=bridge untagged=wlan-mgmt vlan-ids=99
add bridge=bridge tagged=bridge untagged=wlan-block vlan-ids=30
add interface=ether1-WAN list=WAN
add interface=mgmt-vlan list=VLAN
add interface=guest-vlan list=VLAN
add interface=home-vlan list=VLAN
add interface=iot-vlan list=VLAN
add interface=additional-vlan list=VLAN
add interface=block-vlan list=VLAN
add address=192.168.99.1/24 interface=mgmt-vlan network=192.168.99.0
add address=192.168.1.10/24 interface=ether1-WAN network=192.168.1.0
add address=10.0.10.1/24 interface=home-vlan network=10.0.10.0
add address=10.0.20.1/24 interface=additional-vlan network=10.0.20.0
add address=10.0.30.1/24 interface=block-vlan network=10.0.30.0
add address=10.0.40.1/24 interface=iot-vlan network=10.0.40.0
add address=10.0.50.1/24 interface=guest-vlan network=10.0.50.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1-WAN use-peer-dns=no
add address=10.0.10.0/24 gateway=10.0.10.1
add address=10.0.20.0/24 gateway=10.0.20.1
add address=10.0.30.0/24 gateway=10.0.30.1
add address=10.0.40.0/24 gateway=10.0.40.1
add address=10.0.50.0/24 gateway=10.0.50.1
add address=192.168.99.0/24 gateway=192.168.99.1
set servers=1.1.1.1,1.0.0.1
    established,related,untracked
    invalid log=yes log-prefix="[INVALID]"
add action=accept chain=input comment="Full access mgmt" in-interface=\
    mgmt-vlan
    "VLANs can access router services like DNS, Winbox" in-interface-list=\
    VLAN
add action=accept chain=input comment="allow lans to use router dns" \
    dst-port=53 in-interface-list=VLAN protocol=udp
    dst-port=53 in-interface-list=VLAN protocol=tcp
add action=drop chain=input comment="defconf: drop all not coming from mgmt" \
    in-interface=!mgmt-vlan
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid log=yes log-prefix="[INVALID]"
    "Block Internet access from blocked-vlan" in-interface=block-vlan \
    out-interface-list=WAN
add action=accept chain=forward comment="VLAN Internet Access only" \
    connection-state="" in-interface-list=VLAN out-interface-list=WAN
    "allow mgmt-vlan, maybe temp, will be home" in-interface=mgmt-vlan \
    out-interface-list=VLAN
    "Allows port forwarding with the drop all rule" connection-nat-state=\
    dstnat log=yes log-prefix="[PFwd]"
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
    connection-state=new in-interface-list=WAN log=yes log-prefix="[!NAT]"
add action=drop chain=forward comment="drop all else" log=yes log-prefix=\
    catchall-forward
add action=dst-nat chain=dstnat comment=proxy dst-port=443 in-interface=\
    ether1-WAN log-prefix=proxy protocol=tcp to-addresses=10.0.10.150
add action=dst-nat chain=dstnat comment=proxy dst-port=80 in-interface=\
DNS couldn't resolve until I added these I believe.
Connection state has just ""? Should it be new, left alone or, it's not needed at all?
Because of the drop rule at the end this one can get removed:
I'll see if its better to allow intervlan and block or just allow certain vlans access and have the drop rule take care of the rest
add action=accept chain=forward comment="VLAN inter-VLAN routing" in-interface-list=VLAN
or is out interface also needed?
Do you have any recommendations or concerns with my router connecting to the internet?
I'll try getting the Chromecast working in iot to the main and guest vlans.
Using iperf3, I take a hit to intervlan routing speed and the CPU can spike to 25%, there might have been a hit for intravlan between ports.
I didn't get the switch chip on the router working. Would it only give wirespeed for intravlan?
If bridge filtering is used, would a L3 switch have to handle the routing with the L2 hanging off it?
Would one of these work or is there another recommendation?
CRS106-1C-5S
CRS305-1G-4S+IN
shibs
Re: Do I have my firewall rules and VLANs correct?
Mon Jan 13, 2020 10:59 pm
Just bumping this.
Users browsing this forum: CZFan, fedus, karlisi and 64 guests
