MUM Europe 2020
mikrum
Hairpin NAT issue
Sat Jan 11, 2020 1:09 am
Using Router OS 6.41.1
I have forwarded a few ports to the internal local IP addresses and I can access the services on those ports from the internet.
But when I try to access these services from inside local network using the public IP address it's not working. (This seems to be called Hairpin NAT https://wiki.mikrotik.com/wiki/Hairpin_NAT)
I added 3 Hairpin rules in /ip firewall nat, one for each port that I have forwarded but that did not help. Here is my configuration:
[admin@MikroTik] > /ip firewall raw print all
 0  D ;;; special dummy rule to show fasttrack counters
      chain=prerouting action=passthrough
[admin@MikroTik] > /ip firewall nat print all
 0    ;;; defconf: masquerade
      chain=srcnat action=masquerade out-interface-list=WAN ipsec-policy=out,none
 1    ;;; masq. vpn traffic
      chain=srcnat action=masquerade src-address=192.168.89.0/24 log=no log-prefix=""
 2    ;;; OpenVPN
      chain=dstnat action=dst-nat to-addresses=192.168.1.110 to-ports=1194 protocol=udp in-interface=ether1 dst-port=1194 log=no log-prefix=""
 3    ;;; Gitlab ssh
      chain=dstnat action=dst-nat to-addresses=192.168.1.110 to-ports=5522 protocol=tcp in-interface-list=WAN dst-port=5522 log=no log-prefix=""
 4    ;;; Hairpin 3
      chain=srcnat action=masquerade protocol=tcp src-address=192.168.1.0/24 dst-address=192.168.1.110 out-interface-list=LAN dst-port=5522 log=no log-prefix=""
 5    ;;; nginx Rev Proxy http
      chain=dstnat action=dst-nat to-addresses=192.168.1.110 to-ports=81 protocol=tcp in-interface=ether1 dst-port=80 log=no log-prefix=""
 6    ;;; Hairpin 1
      chain=srcnat action=masquerade to-ports=80 protocol=tcp src-address=192.168.1.0/24 dst-address=192.168.1.110 out-interface-list=LAN dst-port=81 log=yes log-prefix=""
 7    ;;; nginx Rev Proxy https
      chain=dstnat action=dst-nat to-addresses=192.168.1.110 to-ports=444 protocol=tcp in-interface=ether1 dst-port=443 log=no log-prefix=""
 8    ;;; Hairpin 2
      chain=srcnat action=masquerade to-ports=443 protocol=tcp src-address=192.168.1.0/24 dst-address=192.168.1.110 out-interface-list=LAN dst-port=444 log=yes log-prefix=""
[admin@MikroTik] > /ip firewall mangle print all
 1  D ;;; special dummy rule to show fasttrack counters
      chain=forward action=passthrough
 2  D ;;; special dummy rule to show fasttrack counters
      chain=postrouting action=passthrough
[admin@MikroTik] > /ip firewall filter print all
 1    ;;; defconf: accept established,related,untracked
      chain=input action=accept connection-state=established,related,untracked
 2    ;;; allow IPsec NAT
      chain=input action=accept protocol=udp dst-port=4500
 3    ;;; allow IKE
      chain=input action=accept protocol=udp dst-port=500
 4    ;;; allow l2tp
      chain=input action=accept protocol=udp dst-port=1701
 5    ;;; allow pptp
      chain=input action=accept protocol=tcp dst-port=1723
 6    ;;; allow sstp
      chain=input action=accept protocol=tcp dst-port=443
 7    ;;; defconf: drop invalid
      chain=input action=drop connection-state=invalid
 8    ;;; defconf: accept ICMP
      chain=input action=accept protocol=icmp
 9    ;;; defconf: drop all not coming from LAN
      chain=input action=drop in-interface-list=!LAN
10    ;;; defconf: accept in ipsec policy
      chain=forward action=accept ipsec-policy=in,ipsec
11    ;;; defconf: accept out ipsec policy
      chain=forward action=accept ipsec-policy=out,ipsec
12    ;;; defconf: fasttrack
      chain=forward action=fasttrack-connection connection-state=established,related
13    ;;; defconf: accept established,related, untracked
      chain=forward action=accept connection-state=established,related,untracked
14    ;;; defconf: drop invalid
      chain=forward action=drop connection-state=invalid
15    ;;; defconf:  drop all from WAN not DSTNATed
      chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface-list=WAN
Can you please help me resolve this issue? Thanks.
SiB
Re: Hairpin NAT issue
Sat Jan 11, 2020 1:20 pm
Doing a HairPinNat I never use any interface like out-interface-list=LAN and my action was always action=src-nat to-addresses=192.168.1.1 where 192.168.1.1
is a MikroTik interface. Example:
/ip firewall nat add action=src-nat chain=srcnat dst-address=192.168.1.2 src-address=192.168.1.0/24 to-addresses=192.168.50.1
Try the HairPinNat rule move to up.
Check this case: viewtopic.php?f=2&t=152978&hilit=hairpinnat
MTCNA + MTCRE + MTCINE | ~600 users at ~150 RouterBoards in EMEA | Telegram: @SiB_PL
WinBox Tip: F6 works as ALT+TAB | Gliffy.com - free network schematic | prnt.sc - free ScreenShot software
I will be at MUMEUROPE Prague on 26-27 march 2020
mikrum
Wed Jan 15, 2020 4:35 am
Thanks for your help.
Let's say the public IP assigned to me by my ISP is 2.2.2.2, I added the following rule as the first NAT rule:
 0    ;;; Hairpin
      chain=srcnat action=src-nat to-addresses=2.2.2.2 protocol=tcp src-address=192.168.1.0/24 dst-address=192.168.1.110 dst-port=5522
Then I tried to connect to that ssh service from a local IP address:
[~]$ ssh 2.2.2.2 -p 5522
ssh: connect to host 2.2.2.2 port 5522: Connection refused
Is there anything I am missing?
SiB
Wed Jan 15, 2020 11:25 am
HairPinNat is used when Client and Server are in the same subnet and Client try reach Server via PublicIP (DNAT).
When C and S are in different subnets base vlans then this just work without HairPinNat.
In HairPinNat rule is from LOCAL IP to LOCAL IP via Router LOCAL IP.
from 192.168.1.123 to 192.168.1.2 SNAT via 192.168.1.1 <- one host to host
from 192.168.1.0/24 to 192.168.1.2 SNAT via 192.168.1.1 <- full subnet to host
from 192.168.1.0/24 to 192.168.1.0/24 SNAT via 192.168.1.1 <- full subnet to subnet
Means your rule with 2.2.2.2 is wrong.
mikrum
Wed Jan 15, 2020 2:51 pm
Excuse my ignorance. I understand that rule was incorrect, so changed it to:
 0    ;;; Hairpin
      chain=srcnat action=src-nat to-addresses=192.168.50.1 protocol=tcp src-address=192.168.1.0/24 dst-address=192.168.1.110
But I still get:
[~] $ ssh 2.2.2.2 -p 5522
Given that I am a total noob in networking, could you write the correct rule here?
Thank you very much.
SiB
Wed Jan 15, 2020 3:07 pm
mikrum
Do this:
/ip firewall export file=firewall
Publish file here.
mikrum
Wed Jan 15, 2020 3:28 pm
I have attached the export of firewall rules (firewall_export.rsc)
Again, thank you for your help!
Edit: I updated firewall_export.rsc file (Disabled all hairpin rules expect the one I mentioned above.)
SiB
Wed Jan 15, 2020 8:14 pm
The gold key to solve your problem is to not use in DNAT the in-interface=ether1 because the LAN to LAN network not go by ether1 interface (the WAN interface).
This means all your testing HairPinNat just cannot work in that DNAT rule.
When you cameback to https://wiki.mikrotik.com/wiki/Hairpin_NAT the DNAT was done by:
/ip firewall nat add chain=dstnat protocol=tcp dst-address=1.1.1.1 dst-port=80 action=dst-nat to-address=192.168.1.2
selection was base on PublicIP1 and Port, not on incoming WAN interface.
Your DNAT all use in-interface=ether1. Please change it. I hope you know now what to do.
About SNAT
add chain=srcnat protocol=tcp src-address=192.168.1.0/24 dst-address=192.168.1.110 action=src-nat to-addresses=192.168.50.1
This should be a MikroTik IP Address on LAN interface like bridge1 who have assign the whole subnet 192.168.1.0/24 and common is 192.168.1.1
add chain=srcnat protocol=tcp src-address=192.168.1.0/24 dst-address=192.168.1.110 dst-port=5522 action=masquerade
This is ok. Masq action use interface from routing means a proper one and check his IP address and use it to hide your all 192.168.1.0/24 before 192.168.1.110 as Router itself IP - the 192.168.1.110 thinking he speak only with router and for him a router is like PC in the same subnet and he not use a default gateway to this conversation.
add action=masquerade chain=srcnat comment=Hairpin disabled=yes dst-address=192.168.1.110 dst-port=81 log=yes out-interface-list=LAN protocol=tcp src-address=192.168.1.0/24 to-ports=80
add action=masquerade chain=srcnat comment=Hairpin disabled=yes dst-address=192.168.1.110 dst-port=444 log=yes out-interface-list=LAN protocol=tcp src-address=192.168.1.0/24 to-ports=443
I not checking them but you try log and any analize of situation. Very good. Remember that biggest help you can reach by /tool sniffer and he in this scenario show you more then other tools.
Now I hope it's be easy as easy to correct the DNAT. I not know what you have a WAN interface, static IP or receive dynamic etc. then I not do anythink know about this matter. Write me if you not understand any stuff.
HairPinNat is tricky and very fun. When someone have full understanding what do DNAT and SNAT then many many situation was fix by that like change flow from one IPSec to other one by not existing third adressing... but it's btw.
Good Luck.
Sob
Wed Jan 15, 2020 9:52 pm
Small correction, to-addresses=192.168.50.1 in hairpin/srcnat rule is ok, and to-addresses=2.2.2.2 was ok too. It may be less common, but it will work. It's just the fake address used as new source for connections from LAN client back to LAN server via public address. Anything except addresses from same LAN subnet will work.
The problem here, as was already written, is in-interface=ether1 in dstnat rules. If your public address is static, replace it with dst-address=<public address>. If it's dynamic, use dst-address-type=local. If it's for ports not used by router itself, it's enough. If the same port is used also by router (e.g. 80 for WebFig), you need to add extra dst-address=!<router's LAN address> to exclude it from dstnat, otherwise you wouldn't be able to connect, because everything would be forwarded to internal server.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply. Not intended as incentive for masochists.
mikrum
Thu Jan 16, 2020 12:51 am
Thank you for your help guys. In dstnat rules, I replaced in-interface=ether1 with dst-address=2.2.2.2 and the problem is solved! Woot woot! :)
I don't officially have a static IP address but my experience says that once my ISP assigns an IP to my router, it never changes it. So I should be good.
Thanks a bunch! :D
Sob
Thu Jan 16, 2020 6:50 am
But you never know when it might change. If you use dst-address-type method, it will always work. Or, if you'd be feeling up for some advanced stuff, you can keep using dst-address and use lease script to update it. Cool stuff, everyone would envy you. Or you can go with DDNS and address list. RouterOS offers different ways.
mikrum
Fri Jan 17, 2020 4:28 pm
That's a great suggestion. I changed the rules for (/ip firewall nat) as follows:
add chain=dstnat action=dst-nat to-addresses=192.168.1.110 to-ports=81 protocol=tcp \
      dst-address=!192.168.1.1 dst-address-type=local dst-port=80
add chain=srcnat action=src-nat to-addresses=192.168.50.1 protocol=tcp src-address=192.168.1.0/24 \
So the rules are now independent from the public IP address. Works like a charm! Thanks again :)
Users browsing this forum: Delete and 62 guests
