MUM Europe 2020
baremetal
No internet access on ether1
Tue Feb 11, 2020 6:44 pm
For the begging, I try a very simple setup:
ether1 <---> routerOS <---> PPP (3g Modem)
My PC is connected to ether1. I set an IP address and a DHCP server:
The problem is that there is no internet access on ether1, routerOS itself can ping the internet and load updates.
add address=192.168.0.1/24 interface=ether1 network=192.168.0.0
add name=pool1 ranges=192.168.0.10-192.168.0.100
add address-pool=pool1 disabled=no interface=ether1 name=dhcp1
I added one cellular modems (Quectel UC20):
/interface ppp-client
add apn=web.vodafone.de data-channel=3 disabled=no info-channel=2 name=ppp-out1 pin=**** port=usb1
Ping from routerOS works nice:
[admin@MikroTik] > /ping 192.168.0.100
  SEQ HOST                                     SIZE TTL TIME  STATUS
    0 192.168.0.100                              56 128 0ms
    1 192.168.0.100                              56 128 0ms
    2 192.168.0.100                              56 128 0ms
    3 192.168.0.100                              56 128 0ms
    sent=4 received=4 packet-loss=0% min-rtt=0ms avg-rtt=0ms max-rtt=0ms
[admin@MikroTik] > /ping 8.8.8.8
    0 8.8.8.8                                    56  53 722ms
    1 8.8.8.8                                    56  53 215ms
    2 8.8.8.8                                    56  53 68ms
    3 8.8.8.8                                    56  53 47ms
    sent=4 received=4 packet-loss=0% min-rtt=47ms avg-rtt=263ms max-rtt=722ms
Thank you in advance,
Regards Andreas
baremetal
Re: No internet access on ether1
Tue Feb 11, 2020 6:47 pm
I also try some masquerade:
 add action=masquerade chain=srcnat out-interface-list=all
With no changes.
baremetal
Tue Feb 11, 2020 6:51 pm
Config export:
[admin@MikroTik] > export
# jan/07/2012 02:55:51 by RouterOS 7.0beta4
# software id = M4Q6-NMFP
/port
set 0 name=usb1
/ip cloud
set update-time=no
#error exporting /ipv6/route/rule
#error exporting /routing/policy/selection
/system gps
set set-system-time=no
/system lcd
set contrast=0 enabled=no port=parallel type=24x4
/system lcd page
set time disabled=yes display-time=5s
set resources disabled=yes display-time=5s
set uptime disabled=yes display-time=5s
set packets disabled=yes display-time=5s
set bits disabled=yes display-time=5s
set version disabled=yes display-time=5s
set identity disabled=yes display-time=5s
set ppp-out1 disabled=yes display-time=5s
set ether1 disabled=yes display-time=5s
set ether2 disabled=yes display-time=5s
[admin@MikroTik] >
mkx
Tue Feb 11, 2020 6:57 pm
The NAT config is wrong, it should be like this:
add action=masquerade chain=srcnat out-interface=ppp-out1
Beware that you don't have any firewall whatsoever ... you're walking on thin ice.
BR,
Metod
baremetal
Wed Feb 12, 2020 11:59 am
I try:
Still it does not work.
Config:
[admin@MikroTik] >> export
# jan/07/2012 19:59:36 by RouterOS 7.0beta4
/port
set 0 name=usb1
/ip cloud
set update-time=no
/system gps
/system lcd
/system lcd page
WeWiNet
Wed Feb 12, 2020 12:33 pm
There is no bridge defined with ETH1?
Would that not be needed? And then put the DHCP server onto the bridge?
Also you have no route added nor any default route created.
(you do not show APN setting, where you can add deault route option)
WeWiNet
MTCNA
hapac2, map, hap-lite, ltap-mini, RB4011 (good!), Audience (better) :-) !!!
baremetal
Wed Feb 12, 2020 2:24 pm
Thanks for your replys.
I forget the gatway:
add address=192.168.0.0/16 gateway=192.168.0.1
Now it works!
mkx
Wed Feb 12, 2020 3:04 pm
The subnet mask in DHCP server settings (/16) and in IP address (/24) should be matching.
@WeWiNet: no, bridge is not absolute necessity ... if only single interface (of any type, could be wired, wireless, VLAN, PPP, ...) is part of same L2 (broadcast) domain, then use of bridge makes no sense (most of times).
BR,
Metod
WeWiNet
Thu Feb 13, 2020 12:24 pm
@MKX thanks, was not aware of that.
WeWiNet
MTCNA
Users browsing this forum: anav and 49 guests
