MUM Europe 2020
viccas91
VLan help / ROAS
Thu Feb 13, 2020 5:29 am
Hi... very new here to MK devices and config.
I do have experience in other platforms, but just acquired an hAP... the company i work for now uses everything MikroTik for routing and PtP.
Need to catch up.
Anyway, with this hAP i used defcon.
Then created a new vlan assigned to either a bridge or an interface with its own network, dhcp pool and server, however i cant get the devices on tagged vlan to get an IP on the AP side as it goes to a managed switch that worked with the previous router. The idea is to use Router On A Stick for this.
Apreciate any help.
Print of config:
# model = 951Ui-2nD
add admin-mac=E4:8D:8C:CF:AB:A8 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=\
MikroTik-CFABAC wireless-protocol=802.11
/interface vlan
add interface=bridge name=error404 use-service-tag=yes vlan-id=3
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add name=default-dhcp ranges=192.168.10.10-192.168.10.254
add name=error404 ranges=192.168.11.10-192.168.11.100
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add address-pool=error404 disabled=no interface=error404 name=error404
/interface bridge vlan
add bridge=bridge tagged=error404 vlan-ids=3
add address=192.168.10.1/24 comment=defconf interface=bridge network=\
192.168.10.0
add address=192.168.11.1/24 interface=error404 network=192.168.11.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=5m
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
add address=192.168.10.0/24 comment=defconf dns-server=9.9.9.9 domain=\
castillohome gateway=192.168.10.1
add address=192.168.11.0/24 dns-server=9.9.9.9 domain=Error404 gateway=\
192.168.11.1
set servers=9.9.9.9
/ip dns static
established,related,untracked
invalid
disabled=yes in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip firewall mangle
add action=passthrough chain=forward in-interface=ether1 out-interface=error404
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
out,none out-interface-list=WAN
/ip service
set telnet disabled=yes
set ssh disabled=yes
/system clock
set time-zone-name=America/Caracas
/tool mac-server
/tool mac-server mac-winbox
tdw
Re: VLan help / ROAS
Thu Feb 13, 2020 1:19 pm
Setting use-service-tag=yes for the VLAN is likely to be wrong. Unless you have a complex setup VLANs normally use the customer rather than service tag type.
Without vlan-filtering=yes on the bridge (under /interface bridge) it will act like an unmanaged switch - any tagged VLANs will pass freely across any ports and all of /interface bridge vlan is ignored. You may wish to use safe mode when enabling it, this will roll back the configuration if you loose connectivity e.g. due to a bad configuration.
A bridge has two personalities, it is both a switch and an interface to the CPU, and so it has to be included in any /interface bridge vlan configurations if you wish the traffic to reach the CPU. Another common mistake is to add the VLAN interface instead of the bridge as you have.
The /ip firewall mangle rule is redundant, it does nothing and is not required. You may wish to review the filter and NAT rules depending on what traffic flows you want to allow and forbid.
anav
Wed Feb 19, 2020 5:38 pm
This is the best reference for vlans............
viewtopic.php?f=13&t=143620
Second best perhaps this one.........
https://wiki.mikrotik.com/wiki/Manual:Bridge_VLAN_Table
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
Users browsing this forum: No registered users and 43 guests
