MUM Europe 2020
mur
MikroTik rb951g-2hnd VS RB951Ui-2HnD
Thu Feb 13, 2020 9:03 pm
Hi everyone,
Since I'd like to get serious about learning networking, I'm thinking about buying either of the these two devices and enter in the Mikrotik world:
https://mikrotik.com/products/compare/R ... 951Ui-2HnD
What really are the difference between the two devices?
Is it just a matter of port speed?
Can they both act as switches and manage VLANs?
Thank you
dareru
Re: MikroTik rb951g-2hnd VS RB951Ui-2HnD
Fri Feb 14, 2020 7:19 pm
As you can see in the comparison, the 951G has only the gigabit ports. In my experience in real-world applications with the same configuration such as bandwidth management, you can only use gigabit on between host computers. You cannot increase its output from WAN to over 60Mbps, even if your internet connection is above 100mbps.
rooted
Fri Feb 14, 2020 7:48 pm
What makes you want to choose those over the hAP ac²?
With the hAP ac² you get better wireless (dual-band/w AC), much better CPU performance, in a package that isn't noticeably more expensive.
All RouterOS devices (with multiple Ethernet ports) can do what you want.
mur
Fri Feb 14, 2020 8:34 pm
Yes, I'm going to buy this HAP ac². A friend of mine told me the same.
I'd like also to know if I can get internet connection via usb tethering from smartphones to this device, and also if this device can act as a Layer 3 swtich for interVlan
Thankyou
Users browsing this forum: keithy and 52 guests
