BV2020
LTE "not running" with no internet
Wed Mar 18, 2020 7:57 am
ROS 6.47beta35. LM940 modem. Routerboard RBLHGR.
Steps taken:
- Modem set to usb2.0
- Modem in LTE mode (and ROS reading it)
-Using same APNs in this modem as the last with the same sim card
-LTE is enabled
ISSUE:
-No internet
-LTE1 is "not running"
-Registration Status: searching
I have found these errors in the log:
Buffer lte
Topics lte
error Message SXTR_LTE: lte1 SMS storage set failed ( I do not have a SXTR_LTE. )
Topics lte async: Message SXTR_LTE: lte1: rcvd +CME ERROR: operation not supported
I don't know what else to check.
SiB
Forum Veteran
Forum Veteran
Re: LTE "not running" with no internet
Wed Mar 18, 2020 11:42 am
Please do reboot
wait 2minutes to grab logs
Run writing logs to file by:
/log print file="logs.txt"
Add this file to forum.
PS. Please not create any more new post at forum.
MTCNA + MTCRE + MTCINE | ~600 users at ~150 RouterBoards in EMEA | Telegram: @SiB_PL
WinBox Tip: F6 works as ALT+TAB | Gliffy.com - free network schematic | prnt.sc - free ScreenShot software
I will be at MUMEUROPE Prague on ?? ?? 202?
SiB
Forum Veteran
Forum Veteran
Wed Mar 18, 2020 2:41 pm
At start disable the GSM network, the LM940 not support that ! 3G and 4G only are support. ROS command:
/interface lte set lte1 network-mode=3g,lte
Maybe that ROS try enable GSM=2G who is not supported create you a problem.
At LM940 AT command manual I see that commands and Telit post (https://www.telit.com/technical-forum/o ... t-allowed/) who describe what to check:
Page 66, SIM/PIN status by
/interface lte at-chat lte1 input="AT+CPIN\?"
Page 55, Registration in network by
"enable network registration unsolicited result code"
/interface lte at-chat lte1 input="AT+CREG=1"
+CREG: <stat>
Where:
<stat>
0 - not registered, ME is not currently searching a new operator to register to
1 - registered, home network
2 - not registered, but ME is currently searching a new operator to register to
3 - registration denied
4 - unknown
5 - registered, roaming
Wait some time and repeat by
/interface lte at-chat lte1 input="AT+CREG\?"
+CREG: 0,2 (the MODULE is in network searching state)
+CREG: 0,1 (the MODULE is registered)
Page 198, Serving Cell Information, After registration try this:
/interface lte at-chat lte1 input="AT#SERVINFO"
Good Luck and give feedback, and LOGs in file
BV2020
Wed Mar 18, 2020 4:54 pm
Please do reboot
Here is the log
logs.txt
Users browsing this forum: Bry and 52 guests
