riodavinci1
beginner need help pppoe connection
Mon Mar 23, 2020 6:06 pm
hey guys this is my first mikrotik project my ISP provide me with PPPoe connection and from my basic networking knowledge i can ping the MDU and my PC but with no internet access can you help me where is the error and maybe i missed up ?
# jan/02/1970 01:54:28 by RouterOS 6.46
# software id = Y84I-F7H7
# model = RouterBOARD 3011UiAS
# serial number = B88F0AD655E5
add admin-mac=74:4D:28:B2:2D:0B auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] name="ether1 wan"
/interface pppoe-client
add add-default-route=yes disabled=no interface="ether1 wan" max-mru=1480 \
max-mtu=1480 mrru=1600 name=pppoe-wan password=hide user=hide
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=pool1 ranges=192.168.10.1-192.168.10.254
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
/ppp profile
set *0 change-tcp-mss=no
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp1
add comment=defconf interface="ether1 wan" list=WAN
add address=192.168.88.1/24 comment=defconf disabled=yes interface=bridge \
network=192.168.88.0
add address=192.168.30.2/30 interface="ether1 wan" network=192.168.30.0
add address=10.10.10.1/24 interface=ether2 network=10.10.10.0
set allow-remote-requests=yes servers=50.60.170.34
/ip dns static
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add distance=1 gateway=192.168.30.1
/tool mac-server
/tool mac-server mac-winbox
Matthiastik
Re: beginner need help pppoe connection
Wed Mar 25, 2020 5:26 am
* what does the log says about PPPoE client connected or trying to connect?
* do you see in IP route PPPoE-xxx reachable ?
* suggest adding 0.0.0.0/0 with gateway of PPPoE in IP-route can not hurt
* Seems like PPPoE out interface is missing in IP-NAT configuration the Masqurade rule and sorry do not know what MDU means
cheers
tdw
Wed Mar 25, 2020 2:39 pm
You have disabled TCP MSS adjustment in the PPP profile, this often breaks TCP sessions, change to
/ppp profile
set *0 change-tcp-mss=yes
The LAN IP addresses should be applied to the bridge not a member port (in this case ether2), change to
add address=10.10.10.1/24 interface=bridge network=10.10.10.0
Add the PPPoE interface to the WAN interface list so the default configuration rules treat the PPPoE connection as a WAN
add interface=pppoe-wan list=WAN
The NAT rule should specify the interfaces to which it applies
Finally you have a default route via 192.168.30.1, remove/disable it as this may be taking precedence over the default route created by the PPPoE client.
Users browsing this forum: No registered users and 25 guests
