Matthiastik
Port nocking
Wed Mar 25, 2020 5:29 pm
good morning,
I have port knocking configured in my RB4011 and sometimes i can not login but after trying a bit later i can an log says
seeing me knocking 5 times
winbox login failed
knocking x times
login successful with my ip address
question
could it be that their internet service of the client is saturated when i try logging in and it is at times the case!?
could it be my internet service that is failing ?.
tried to make an QoS but that will only limit upload not download that i can not control and only ISP could.
Could my assumptions be correct ?
cheers,
jvanhambelgium
Re: Port nocking  [SOLVED]
Wed Mar 25, 2020 7:39 pm
In theory this is possible.
You are using UDP or TCP knocks ?
Portknocks might not always be very robust, but for me it works fine.
My app on my phone that performs the knocking transmits the packets with some time in between. I've had a another app that was not working well.
So might be also dependant a bit...
Matthiastik
Re: Port nocking
Wed Mar 25, 2020 7:53 pm
Thanks for the response ...
I am using TCP ..
Cheers,
anav
Re: Port nocking
Wed Mar 25, 2020 8:08 pm
What app do you use for port knocking??
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
MTUNA Certified, by the Ascerbic Llama!
jvanhambelgium
Re: Port nocking
Wed Mar 25, 2020 9:25 pm
I use "Port Knocker" on my Galaxy S6 , created by Ahsan Rabbani (symbol of a RJ45 socket).
On my phone & android release it proved stable & good.
Matthiastik
Re: Port nocking
Wed Mar 25, 2020 11:52 pm
Keep it simple ...
Winbox or any web browser
cheers,
anav
Re: Port nocking
Wed Mar 25, 2020 11:53 pm
Ahhh no IOS version, thanks.
jvanhambelgium
Re: Port nocking
Thu Mar 26, 2020 8:43 am
Keep it simple ...
cheers,
For management that is true, however I use port-knocking to "open" my Mikrotik to other services I run at home (eg. Plex for video streaming, Logitech Media Server for my audio streaming etc, accessing my Splunk etc)
I do not perform any sort of router-management remotely.
anav
Re: Port nocking
Thu Mar 26, 2020 2:13 pm
Keep it simple ...
cheers,
Nice!
I hope the keep it simple dude meant via VPN of some sort.
jvanhambelgium
Re: Port nocking
Thu Mar 26, 2020 2:55 pm
Keep it simple ...
cheers,
Nice!
Well "VPN" cannot always solve all scenario's because it is bound to only your phone/device on which the VPN client is installed.
eg. you visit friends and want to watch movie from your media-server, now it is easy : You simply connect to friends Wifi and performs port-knock sequence and then their public-IP is now allowed for several hours. Now they can go on their smartTV, launch Plex and we can see some movies. Or if they use a Chromcast-dongle they also can do it.
So yeah, many solutions, including VPN and/or port-knock possible depending a bit on the use-case.
anav
Re: Port nocking
Thu Mar 26, 2020 6:36 pm
Nice!
Users browsing this forum: Baidu [Spider], Joe1962, Traveler382 and 64 guests
