larsac
Connection between SFP / SFP+
Thu Apr 30, 2020 9:55 pm
can I somehow establish a connection between a router with an SFP port (e.g. Hex PoE or RB3011UiAS-RM) and an SFP+ port on a switch (e.g. CRS326-24G-2S+RM or CRS328-24P-4S+RM) ?
Lars
mbovenka
Re: Connection between SFP / SFP+
Thu Apr 30, 2020 10:18 pm
Depends on what type your SFP+ is. Copper ones are often multi-rate and will do 1G. Optics not so much. Putting an SFP in your switch is probably the easiest.
larsac
Fri May 01, 2020 9:35 am
So an SFP module will work in the SFP+ cage of the above mentioned switch?
Lars
mbovenka
Fri May 01, 2020 11:14 am
Yes, they will. You can look at the SFP compatibility list to be sure.
pe1chl
Fri May 01, 2020 11:42 am
And when it is a local connection you can consider a DAC cable, but also after checking compatibility. I think with a RB3011 there are problems with that.
mbovenka
Fri May 01, 2020 11:48 am
4011s too (they don't support passive DACs)
larsac
Fri May 01, 2020 11:55 am
Great, thanks for answers, these help a lot!
Lars
bdouse
Wed May 27, 2020 9:12 pm
Can a CRS309 switch be connected to a CRS125 via the SFP+ and SFP ports, respectively, using a Cable Matters 10GBASE-CU DAC Twinax cable? I tried it myself, but couldn't get it to work. I was able to set the CRS309 SFP+ port's link speed to 1GB, which got me some link lights, transmit activity, and "link up" status. But, nothing on the receive side at all. I got nothing on the CRS125 switch at all. No link lights on the SFP port and a "no link" status in the web interface. I contacted the Cable Matter Rep and he said that it should work, but that I should check with Microtik to confirm the compatibility of these two switches connecting together like that. Any help will be greatly appreciated.
antikurjers
Wed Dec 30, 2020 8:50 pm
Yo! I tried to connect SFP (RB2011UiAS-2HnD-IN) to SFP+(CRS305-1G-4S-IN) with EDGE 10G-SFP-300-MT SFP+ transceiver. I see it in RB2011UiAS-2HnD-IN but the connection does not work.
Isn't compatible?
karlisi
Mon Jan 04, 2021 9:05 am
SFP+ module in SFP cage (RB2011) won't work. SFP module in SFP+ cage should.
Karlis
pe1chl
Mon Jan 04, 2021 10:29 am
Yes, you need to use SFP materials. Not SFP+ in SFP mode, I think not even that would work.
And also not a SFP module at one end connected via fiber to an SFP+ module at the other end, that likely also won't work.
Users browsing this forum: memelchenkov and 93 guests
