archerious
Removing VLAN 0 802.1p tags on CRS112?
Sun May 17, 2020 5:09 am
Is it possible?
My ISP tags things with vlan 0 802.1p tags, and I want to remove them then from ether4 and then pass ether6 through to my router.
There is a thread about this, so far only tp-link switches and some routers like RB4011 can remove it.
I don't understand why my CRS112 can't, but it doesn't work.
Cisco switches apparently also allow removing 802.1p tags.
Anyone have any advice?
RB4011 Former: CCR2004, hEX (RB750Gr3), ER4
Aruba 2930F, CSS326, CRS309, CRS112-PoE Former: Ubiquiti XG-16 & ES-10X
Wireless Wire
AT&T Fiber 1000/1000
http://tlopez.cc/images/hex_is_a_beast.PNG
http://tlopez.cc/images/ccr2004_speedtest.png
andriys
Re: Removing VLAN 0 802.1p tags on CRS112?
Sun May 17, 2020 8:59 pm
I don't know if it is possible to strip the priority tags on your switch, but am very curious why do you need to do that at all?
archerious
Sun May 17, 2020 9:05 pm
If I don't dhcp client won't get an ip address even though dot1x client shows authenticated.
AT&T does this intentionally to try to force us all to use their shitty gateway units that lack a real bridge mode.
Here's an example: Image
Wireless Wire
archerious
Sun May 17, 2020 9:51 pm
While I failed to get my CRS112 to strip vlan headers, surprisingly the CSS326 was able to do so without much effort.
Wireless Wire
Users browsing this forum: DimaFIX, gfhahsvhj and 54 guests
