lancer
RB2011iL bottleneck to 400mbps internet connection
Tue May 19, 2020 11:16 pm
This seems like a pretty beginner question, I want to make sure I'm not missing something here, so thanks in advance for hearing me out :D
I am using my RB2011iL with a Charter/Spectrum 400mbps internet connection... with a laptop hard wired connected directly to the modem, I'll see 350mbps+ download... with the RB in the equation I'm seeing 85-108 max. I'm only using port 1 and 2 on the RB, and both interfaces are showing Rate of 1Gpbs on the web interface. CPU is showing max 60% during a speed test. Memory is ok.
I'm ok upgrading to a more capable unit, but I don't want to just try buying something new without knowing exactly what's serving as the bottleneck.
Any help is much appreciated!
ingdaka
Re: RB2011iL bottleneck to 400mbps internet connection
Wed May 20, 2020 8:52 pm
Enable fast track!
Ilir Daka
Electronic & Network Engineer
E-mail: ilirdaka@live.com
Mob: +355692982151
WhatsApp: +355692982151
Mikrotik Official Consultant
CCNA | Fortinet NSE3 | MTCRE | MTCSE | MTCWE | RIPE NCC Certified Professional
pe1chl
Wed May 20, 2020 8:57 pm
You forgot to include your config.
Did you update the RouterOS? Did you recently reset it to defaults?
solar77
Long time Member
Long time Member
Thu May 21, 2020 2:04 pm
https://mikrotik.com/product/RB2011iL-I ... estresults
look under 512 byte, routing performance
MTCNA MTCTCE UEWA
pukkita
Trainer
Trainer
Thu May 21, 2020 4:45 pm
A 2011iL isn't what I would use in 2020 for a 400Mbps line... definitely enabling fasttrack, and tuning the firewall would be a must, but even though, don't expect 400Mbps performance.
How do you get your internet IP? pppoe? if so, expect around 150-250Mbps max with tuning.
I'd get an HeX straight away and leave that 2011iL as switch and don't look back.
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
mbovenka
Thu May 21, 2020 4:59 pm
This. Or a hAP ac². Only a little more and will do 400Mbps standing on its head.
Users browsing this forum: solar77 and 40 guests
