HawkOTD
Replace Vodafone router
Fri May 22, 2020 4:14 pm
I want to replace my Vodafone Station with a MikroTik router, the Vodafone requirements for router replacement are as follows:
ADSL 2+
ITU: G.992.1, G.992.5 over POTS
PPPoE Routed (RFC2516)
Type SRV query DNS (RFC 2782)
codec: G.729, G.711 A-law, T.38.
Does the hEX S model support those standards?
Also I have around ~60 devices that talk through this router, is this router enough to support them or if not what router is better?
msatter
Re: Replace Vodafone router
Fri May 22, 2020 4:53 pm
You will have to set the Vodafone router to bridge if that is posdible. Miktotik does not support ADSL/VDSL in any way on it's own.
One RB4011 (cooled) and a RB760iGS (hEX S) in series. 4011 Does PPPoE/IKEv2.
Running:
RouterOS 6.47 / Winbox 3.24 / MikroTik APP 1.3.12
NordVPN viewtopic.php?f=2&t=158439&p=781009 for multiple connections.
HawkOTD
Fri May 22, 2020 6:02 pm
Thanks for the reply. That's unfortunate, I really hoped it was as I loved the idea of having a simple and fast ethernet-only router without all the stuff that gets bundled with the brands' one.
mutluit
Long time Member
Long time Member
Fri May 22, 2020 6:19 pm
Like @msatter said: if that Vodafone device can be configured as a bridge (ie. modem-passthru) then you could use PPPoE of the MT device:
https://wiki.mikrotik.com/wiki/Manual:Interface/PPPoE
Users browsing this forum: roe1974, YaCy [Bot] and 42 guests
