/export hide-sensitive file=anynameyouwishPost output of "/export hide-sensitive" between code brackets, I.e.Code: Select all
# jun/04/2020 21:17:38 by RouterOS 6.46.6
# software id = JE5F-K09Z
# model = 2011UiAS-2HnD
# serial number = B9070A937FC8
add admin-mac=74:4D:28:86:91:2B auto-mac=no comment=defconf name=bridge
set [ find default-name=ether3 ] disabled=yes
set [ find default-name=ether4 ] disabled=yes
set [ find default-name=ether5 ] disabled=yes
set [ find default-name=ether6 ] disabled=yes
set [ find default-name=ether7 ] disabled=yes
set [ find default-name=ether8 ] disabled=yes
set [ find default-name=ether9 ] disabled=yes
set [ find default-name=ether10 ] disabled=yes
set [ find default-name=sfp1 ] disabled=yes
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=0 band=2ghz-b/g/n channel-width=\
20/40mhz-XX country=no_country_set disabled=no distance=indoors \
frequency=auto frequency-mode=manual-txpower mode=ap-bridge ssid=Cassini \
wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
supplicant-identity=MikroTik
add name=dhcp ranges=192.168.0.1-192.168.0.250
add address-pool=dhcp disabled=no interface=bridge name=defconf
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
sword,web,sniff,sensitive,api,romon,dude,tikapp"
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp1
add address=192.168.0.251/24 comment=defconf interface=ether2 network=\
192.168.0.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
/ip dhcp-server lease
add address=192.168.0.7 address-lists="" comment="BEIC-LP LAN" lease-time=10m \
mac-address=1C:83:41:09:F3:11 server=defconf
add address=192.168.0.2 client-id=1:90:2b:34:3f:6f:76 comment=AGI-PC \
mac-address=90:2B:34:3F:6F:76 server=defconf
add address=192.168.0.3 comment=ALEX-PC mac-address=90:2B:34:A2:07:8A server=\
defconf
add address=192.168.0.1 comment=BEIC-PC mac-address=90:2B:34:74:FE:CE server=\
defconf
add address=192.168.0.5 comment="BEIC-LP WAN" mac-address=18:3D:A2:2A:86:18 \
server=defconf
add address=192.168.0.6 comment=PETRA-PC mac-address=90:2B:34:B6:14:01 \
server=defconf
add address=192.168.0.120 comment=ORANGE-PI-ONE mac-address=5E:21:83:A6:95:7A \
server=defconf
add address=192.168.0.132 comment=BEIC-SERVER mac-address=B4:2E:99:28:D9:71 \
server=defconf
add address=192.168.0.112 comment=IOT-EXAMPLER mac-address=A0:20:A6:04:09:10 \
server=defconf
add address=192.168.0.177 comment=INT-DPC-001 mac-address=DE:AD:BE:EF:FE:ED \
server=defconf
add address=192.168.0.178 comment=ARDUINO-31 mac-address=74:69:69:2D:30:31 \
server=defconf
add address=192.168.0.179 comment=ARDUINO-32 mac-address=74:69:69:2D:30:32 \
server=defconf
add address=192.168.0.243 comment=WD-TV-LIVE mac-address=00:90:A9:93:4B:B0 \
server=defconf
add address=192.168.0.244 comment=WD-TV-LIVE-2 mac-address=00:90:A9:92:8F:68 \
server=defconf
add address=192.168.0.150 comment=beicNET-Systems-D01 mac-address=\
5C:CF:7F:AC:FB:8B server=defconf
add address=192.168.0.242 comment=AnyCast-773BCA mac-address=\
00:F0:00:40:00:04 server=defconf
add address=192.168.0.245 comment=HPLJ1320NW mac-address=00:11:85:D2:2C:93 \
server=defconf
add address=192.168.0.131 comment=BEIC-NAS mac-address=00:11:32:9D:64:51 \
server=defconf
add address=192.168.0.247 comment=VivaxTV mac-address=7C:82:74:37:16:34 \
server=defconf
add address=192.168.0.81 comment=BEIC-NAS-2 mac-address=30:46:9A:B2:B8:6A \
server=defconf
add address=192.168.0.246 comment=LGwebOSTV mac-address=14:C9:13:3F:CB:D6 \
server=defconf
add address=192.168.0.4 client-id=1:ac:d5:64:10:46:eb comment=AGI-LP \
mac-address=AC:D5:64:10:46:EB server=defconf
add address=192.168.0.0/24 comment=defconf dns-server=8.8.8.8,8.8.4.4 \
gateway=192.168.0.251 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.0.251 name=router.lan
/ip firewall address-list
add address=XXXXXX comment="DDNS Resolver" list="WAN IP"
established,related,untracked
add action=accept chain=input comment="Accept DNS - TCP" in-interface-list=\
LAN port=53 protocol=tcp
add action=accept chain=input comment="Accept DNS - UDP" in-interface-list=\
LAN port=53 protocol=udp
add action=fasttrack-connection chain=forward comment="DNS Fasttrack - TCP" \
dst-port=53 protocol=tcp
add action=fasttrack-connection chain=forward comment="DNS Fasttrack - UDP" \
dst-port=53 protocol=udp
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
invalid
connection-state=invalid
in-interface-list=!LAN
add action=masquerade chain=srcnat comment="HAIRPIN NAT" dst-address=\
192.168.0.0/24 out-interface-list=LAN src-address=192.168.0.0/24
add action=dst-nat chain=dstnat comment="BEIC-NAS2 - iSCSI" dst-address-list=\
"WAN IP" dst-port=3260 protocol=tcp to-addresses=192.168.0.81 to-ports=\
3260
add action=dst-nat chain=dstnat comment="Synology GUI" dst-address-list=\
"WAN IP" dst-port=4001 protocol=tcp to-addresses=192.168.0.131 to-ports=\
4001
add action=dst-nat chain=dstnat comment="Synology WebDAV" dst-address-list=\
"WAN IP" dst-port=4006 protocol=tcp to-addresses=192.168.0.131 to-ports=\
4006
add action=dst-nat chain=dstnat comment="HTTP Server" dst-address-list=\
"WAN IP" dst-port=8008 protocol=tcp to-addresses=192.168.0.132 to-ports=\
8008
add action=dst-nat chain=dstnat comment="FTP Server" dst-address-list=\
"WAN IP" dst-port=21 protocol=tcp to-addresses=192.168.0.132 to-ports=21
add action=dst-nat chain=dstnat comment="MariaDB Server" dst-address-list=\
"WAN IP" dst-port=3307 protocol=tcp to-addresses=192.168.0.132 to-ports=\
3307
add action=dst-nat chain=dstnat comment="RDP Server" dst-address-list=\
"WAN IP" dst-port=5555 protocol=tcp to-addresses=192.168.0.132 to-ports=\
5555
add action=dst-nat chain=dstnat comment="Beicnet Systems D1" \
dst-address-list="WAN IP" dst-port=21000 protocol=tcp to-addresses=\
192.168.0.150 to-ports=21000
add action=dst-nat chain=dstnat dst-address-list="WAN IP" dst-port=80 \
protocol=tcp to-addresses=192.168.0.150
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh disabled=yes port=222
set api disabled=yes
set api-ssl disabled=yes
/ip smb
set allow-guests=no domain=BEAG enabled=yes
/ip smb shares
add comment="USB Drive External" directory=/disk1 max-sessions=25 name=\
external
/ip smb users
add name=service read-only=no
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/lcd interface
set sfp1 disabled=yes
set ether3 disabled=yes
set ether4 disabled=yes
set ether5 disabled=yes
set ether6 disabled=yes
set ether7 disabled=yes
set ether8 disabled=yes
set ether9 disabled=yes
set ether10 disabled=yes
/system clock
set time-zone-name=Europe/Belgrade
/system identity
set name=Prometheus
/system scheduler
add interval=10m name="Refresh DDNS" on-event="Dynamic DNS" policy=\
read,write,test start-time=startup
/system script
add dont-require-permissions=no name="Dynamic DNS" owner=admin policy=\
read,write,test source="# No-IP automatic Dynamic DNS update\r\
\n\r\
\n#--------------- Change Values in this section to match your setup -----\
-------------\r\
\n\r\
\n# No-IP User account info\r\
\n:local noipuser \"XXXXXX\"\r\
\n:local noippass \"XXXXXX\"\r\
\n\r\
\n# Set the hostname or label of network to be updated.\r\
\n# Hostnames with spaces are unsupported. Replace the value in the quotat\
ions below with your host names.\r\
\n# To specify multiple hosts, separate them with commas.\r\
\n:local noiphost \"XXXXXX\"\r\
\n\r\
\n# Change to the name of interface that gets the dynamic IP address\r\
\n:local inetinterface \"ether1\"\r\
\n\r\
\n#-----------------------------------------------------------------------\
-------------\r\
\n# No more changes need\r\
\n\r\
\n#:global previousIP;\r\
\n\r\
\n:if ([/interface get \$inetinterface value-name=running]) do={\r\
\n# Get the current IP on the interface\r\
\n :local currentIP [/ip address get [find interface=\"\$inetinterface\"\
\_disabled=no] address];\r\
\n\r\
\n# Strip the net mask off the IP address\r\
\n :for i from=( [:len \$currentIP] - 1) to=0 do={\r\
\n :if ( [:pick \$currentIP \$i] = \"/\") do={\r\
\n :set currentIP [:pick \$currentIP 0 \$i];\r\
\n }\r\
\n }\r\
\n\r\
\n :local previousIP [:resolve \"\$noiphost\"];\r\
\n\r\
\n :log info \"DNS IP: \$previousIP, interface IP: \$currentIP\";\r\
\n\r\
\n :if (\$currentIP != \$previousIP) do={\r\
\n :log info \"No-IP: Current IP \$currentIP is not equal to previous\
\_IP \$previousIP, update needed\";\r\
\n # :set previousIP \$currentIP;\r\
\n :local url \"http://dynupdate.no-ip.com/nic/update\\3Fmyip=\$curre\
ntIP\";\r\
\n :log info \"No-IP: Sending update for \$noiphost\";\r\
\n /tool fetch url=(\$url . \"&hostname=\$noiphost\") user=\$noipuser\
\_password=\$noippass mode=http dst-path=(\"no-ip_ddns_update-\" . \$host \
. \".txt\")\r\
\n :log info \"No-IP: Host \$noiphost updated on No-IP with IP \$curr\
entIP\";\r\
\n \r\
\n } else={\r\
\n :log info \"No-IP: Previous IP \$previousIP is equal to current IP, n\
o update needed\";\r\
\n }\r\
\n} else={\r\
\n :log info \"No-IP: \$inetinterface is not currently running, so there\
fore will not update.\";\r\
\n}"
/tool mac-server
/tool mac-server mac-winbox
192.168.0.0
should be
add address=192.168.0.251/24 comment=defconf interface=bridge network=\
192.168.0.0
Dont think you need these at all (remove)
A bit of extra stuff in your hairpin nat rule...... to remove
Now for hairpin nat to work,
one needs to know if your WAN IP is static or dynamic?:?
also one needs to know which SERVER(s) are you specifically looking to be able to use this functionality??
This will determine the structure of your rules.
If you have a clould ddns place from MT, also could be helpful or if you have one from a different provider AND you can set a C name to point the MT cloud ddns.
Hi Beic, nice work!
You have two options for DYNAMIC WANIP and dstnat rules when working with hairpin nat otherwise the following rule would be used.
{no hairpin nat - standard dstnat rule for dynamic wanip}
add chain=dstnat action=dst-nat in-interface-list=WAN
protocol=tcp dst-port=9000 to-address=192.168.88.50
With hairpin nat one has to add the sourcenat rule for both dynamic and static wanips (already done) and special dstnat rules for dynamic wanips.
1. Use the cloud DDNS service and have more regular looking dstnat rules
2. Use modified dstnat rules.
To compare here is the format for a fixed WANIP which requires no special changes (they work with or without hairpin nat just fine).
add chain=dstnat action=dst-nat dst-address=FIXED WANIP
However we have to deal with dynamic WANIP.
Method 1:
Use the MT cloud service*** and very slightly alter dstnat rules (works for internal and external users as well).
add action=dst-nat chain=dstnat dst-address-list=cloudDNS
protocol=tcp dst-port=9000 to-addresses=192.168.88.50
Note: To use method 1 -
a. Turn on mikrotik cloud service
b.Go to IP-> Firewall-> Address lists, create an entry with whatever name you wish e.g "cloudDDNS" and at the address type the cloud DDNS name of your Mikrotik...
This will automatically resolve the name to your Public IP address....
Method 2:
Modify Existing DST nat rules for a dynamic WANIP.
add chain=dstnat action=dst-nat dst-address=!192.168.88.1 \
dst-address-type=local protocol=tcp dst-port=9000 to-address=192.168.88.50
Note: where 192.168.88.1 is the lanip of the subnet, your server AND users are located on..
No, LOL, those were just examples, the numbers not to be taken literally.
192.168.88.50 is the IP address of the server on the LAN in the example (not a legitimate public IP number anyway)
The 9000 port is the port that your server provides to access the server..........
Take one of your rules. Its wrong for any setup regardless with dst-address list (or at least never seen it setup like that).
3260
In any case the PORT 9000 is equivalent to your port 3260, note that the to port is NOT required if same as dst-port!
Also the ..88.50 is equivalent to your server IP 192.168.0.81
add action=dst-nat chain=dstnat comment="BEIC-NAS2 - iSCSI" dst-port=3260 \
protocol=tcp to-addresses=192.168.0.81 to-ports=3260
yes since you don't specify an in-interface or dst-address or some other specifier it should kick from outside networks also
If you rdp with the local address rather than the domain name do you experience latency?
So latency in the INITIAL RDP setup right ? Not a CONTINUOUS SLOW/DELAYED operation during a session ?Yes, I'm talking about local address direct connection (between two computers on a same network range).If you rdp with the local address rather than the domain name do you experience latency?
If you try to reach the rdp server by local ip and still experience latency it is not something related to the above configuration. Since the client and server pc are on the same broadcast domain /24 their ip are directly connected and the router is not involved in the communication. I notice that you have disabled all ethernet interfaces except ethernet 2 for LAN. Are computers connected to another switch behind ethernet 2? Are you trying to access from wireless interface?
Apart from the initial dhcp negotiation the router will not involve in the internal communication of the hosts that are directly connected with each other if you use local ip address. If you use domain name that is translated to some ip address public or local then there may be something related to the name resolving delay or to nat if resolving to the public ip rather than the local ip
Disagree with my esteemed colleague........
The below is not correct.
ASSUMING NO HAIRPIN NAT - (hairpin nat only required if you have users on the same lan as the server that need access the server and you want them to use the WANIP address of the router to get them there instead of the direct LANIP)
Correct NORMAL dstnat rules.....
DYNAMIC WANIP
add action=dst-nat chain=dstnat comment="BEIC-NAS2 - iSCSI" in-interface-list=WAN dst-port=3260 \
FIXED WANIP (static)
add action=dst-nat chain=dstnat comment="BEIC-NAS2 - iSCSI" dst-address=fixedwanip dst-port=3260 \
3260
Nope,
Use in-interface-list=WAN, not dst-address="an address list"
FM
3260
TO
add action=dst-nat chain=dstnat comment="BEIC-NAS2 - iSCSI" in-interface-list=WAN \
Since you don't have that, not sure what the issue is ???
Out of curiosity, how do you determine the contents of the firewall address list called "WAN IP" ??
I see you are getting the IP address from you dyndns site
The dyndns site gets your IP due to the script.
Pretty cool!
DOH, I get it , you are using the same method above (method 1) except with the dnydns provider name vice the MT cloud name.
Well I guess in this case your dst-address will always be accurate and thus a nice work around.
(althought it still doesnt explain why the usual method doesnt work... the mysteries of MT or my lack of knowledge take your pick LOL).
Just for giggles did you also try..... in-interface=eth1 (vice list)?
How are you testing access from external users?
Even with same config, some things may be different. If it would be related to DNS, which probably shouldn't affect all services, but it's not completely impossible, then perhaps Linksys could be automatically adding local DNS entries for DHCP leases, but RouterOS doesn't do that (it needs to be scripted). Just an example. I'd play with packet sniffer, it often shows useful info.Ok, then explain this, if I put back the old Linksys WRT54GL router everything is flying like a rocket (used same settings to configure this MikroTik device).
Yes my bad, I have limited experience but have used many zyxel products and a couple of cisco products besides the usual commercial crap.
There usually is a reason for something not working but in this case I cannot explain why the in-interface-list rule does not work for external users???
In any case, sorry I havent been able to address why that particular setup seems to be an issue but it sounds as you have a viable working config!!
I might be tempted to shorten up your dst nat rules like so................ (and change comments appropriately)
"WAN IP" dst-port=4001,4006 protocol=tcp to-addresses=192.168.0.131
"WAN IP" dst-port=21,3307,5555,8088 protocol=tcp to-addresses=192.168.0.132
add action=dst-nat chain=dstnat comment="Beicnet Systems D1" dst-address-list=\
"WAN IP" dst-port=21000,80 protocol=tcp to-addresses=192.168.0.150
Don't confuse the poor guy
Yes beic, its a good shortcut if not monkeying in the rules too much.
YOu may want to use scheduling for rules if the rules change at select times.
You may also use FW address lists to limit access to external users as well (means they have static addresses or perhaps they have dyndns URLS that the firewall address list can resolve).
As for in-interface-list our good buddy Sob stated:
"If you need port forwarding only from outside, then using in-interface or in-interface-list is the simplest solution, because it will take everything, no matter what the destination address is. Even if some hacker in ISP's network would be sending packets with random destination addresses to your router, this rule would still match and would forward them to target device. The only way how it can not work is when you use wrong interface. For example, if you'd have PPPoE, but instead of using that, you'd use parent ethernet interface.
The reasons against in-interface(-list) and for dst-address(-list) are:
- need for hairpin NAT
- when you have more than one public address and want different config for them
- when you just can't overcome the feeling that it's wrong to match all addresses when you really want only one"
Which is why I asked about pppoe, but you are already pointed I think its straight eth1 standard type cable wan input.
So in conclusion we still dont know why the general rule didnt work, which will bother me to my grave LOL, and that for better definition and security your method is superior.
You kind of are, in the "unfortunate" sense, because it doesn't work for you (not "stricken by poverty", I wouldn't know about that). But you're focusing on wrong details.Who de fak says that I'm poor?!
If the problem is reliably reproducible, it's next best thing after having no problem. As was suggested before, packet sniffer is your friend. Run e.g. Wireshark on target server, capture what happens when you try to connect, and hopefully you'll find something useful.
Statistically irrelevant, for example I use IKEv2 vpn at home and we also use RDP outbound and no issues at all.
Perhaps its the modem LOL, or some weird firewall on PCs......
Sorry, yes you had noted that.......... Send a supout to MT, with some additional evidence and see what they say??
Ur NAT rule order seemed fine to me.
connection-mark=!ipsec connection-state=established,related
You have simple config with nothing special in it. And it's not like the firewall could even slow down packets in a way to give you delays like you see.
Did you check it it could be problem with DNS, as others already suggested? If target machine tries to find client's hostname from IP address and it can't, it takes a while before it gives up. Resulting delay could be exactly what you're describing. So if you have RPD server at 192.168.0.132:5555 and connecting to it is slow, what DNS servers 192.168.0.132 uses? Is it router or something else? If router, does it have functioning DNS? You have nothing in config, so it would come from DHCP client.
Of course this is just something that *could* be happening. Befriend a packet sniffer and you can see what *is* happening.
