coliflower
Export / Import
Fri Jun 26, 2020 9:48 pm
Hi all :-)
I exported all data from my wAP #1, adapted the data inside the file and now I would like to import the data in my wAP #2 ...
Is there any possibility to do it through the current/running setup on #2 or is there some need to reset #2 first and then to import afterwards ?
Thanks in advance !
mutluit
Forum Veteran
Forum Veteran
Re: Export / Import
Sun Jun 28, 2020 6:28 pm
Via GUI you can do System/ResetConfiguration and specify the import script in the field "Run After Reset".
But see also this thread for possible problems: viewtopic.php?t=123656
coliflower
Re: Export / Import
Mon Jun 29, 2020 11:33 am
Thank you very much - I will try in the next days :-)
Regarding "problems" ... I will put the recommended delay in
/delay delay-time=15s
What is still not clear to me is following statement ... I have a wAP-AC, so I need to do it ?
It is important to note that for certain devices, the configuration has to be placed inside the flash\ folder.
Warning: If the device has a folder named "flash", then the confscript.rsc file must be stored in that folder to work with "run-after-reset" command. Everything outside this folder is stored on the RAM drive which contents are deleted on reboot or power cycle.
mutluit
Forum Veteran
Forum Veteran
Re: Export / Import
Mon Jun 29, 2020 3:29 pm
It is device-dependent.
Best is if you copy your script into both folders: to the root folder as well to the flash folder. You can use "ftp" for this.
Users browsing this forum: BillyVan, Egert143, Hominidae and 38 guests
