MUM Europe 2020
Equis
Forum Veteran
Forum Veteran
Shaping
Sat Jun 16, 2007 5:11 am
Hello
I am using queues and they are working fine.
I do see about 5ms extra latency to on my lan an a tad more jitter (not much)
Is that a normal side effect to shaping?
jwcn
Re: Shaping
Sun Jun 17, 2007 6:33 am
Jitter is a term used to talk about wireless signal. I'm not sure I understand what you are asking.
Equis
Forum Veteran
Forum Veteran
Re: Shaping
Sun Jun 17, 2007 7:09 am
I was meaning can be 5ms then 10ms, then 5ms etc
With queues off its 1ms
jwcn
Re: Shaping
Mon Jun 18, 2007 3:13 pm
Sounds like the queue is being hit therefore delaying the packets.
warwick09
Re: Shaping
Mon Jun 18, 2007 4:45 pm
Jitter can also be exhibited in any lan enviroment both wireless and wired. Essentially it is measured according to a "buffer/grace" period. Anything that exceeds this buffer period is considered as being jitter. (I.e a packet that arrives out of the expected time slot)
As for the 5ms increment in latency with queues activated, hmm; not normal in my books. What ros version are you using and what are ram, cpu specs for your router. and if normal pc it might just be the lan card. :?
Regards.
Equis
Forum Veteran
Forum Veteran
Re: Shaping
Tue Jun 19, 2007 3:03 am
Hello
is a RB532 running at 300Mhz
CPU load is about 30%
Users browsing this forum: IPANetEngineer, MSN [Bot], TomaszF and 74 guests
