If I want to use both ISPs fiber 1gig up/down and Cable 100 down 10 up, can I do so without mangling?
Certainly this is a load balancing nightmare which would be probably be setup as a 10:1 ratio
ip route enable [find dst-address="0.0.0.0/0" gateway=8.8.4.4 routing-mark="wan2_SM" ]
delay 1s
foreach IPList in=[/ip firewall address-list find list="LANs_via_SM"] do={
local CurIP [ip firewall address-list get $IPList address ]
local IP3oct [pick $CurIP 0 [find $CurIP "." ([find $CurIP "." ([find $CurIP "."]+1)]+1)]]
ip firewall connection remove [find connection-mark~"wan1_Orange<->LANs" src-address~$IP3oct ]
ip firewall connection remove [find connection-mark~"wan1_Orange<->LANs" reply-src-address~$IP3oct ]
I use mangle to manage that.What is the most efficient way to send users to the better wanip. A simple route rule for mangled traffic?
When ISPx not work, then all conection inside Firewall\Connections gets timeout... in some time... this means user see that internet not work until theyr brower/soft/app not do a new Syn connction who will be send via working ISP OR the old ISPx cameback to life.What if I have a load balance scenario of 10:2 for example, and the primary the 10 fails, no connectivity (I would use external recursive to check).
How does the router then respond??
? you not read a #2Can you give an example config so that I can see how you put it together?
ok, means you mix a 1) point with RecursiveRouting with 3) who detect if wanx working or not.I understand the mangle bit, I use it to. But why the recursive part?
I knew it!!, You are either an alien or a very smart teddy bear!!I hope I write in human form :)
This "1) Recursive Routing" can be done only by MikroTik Developers TeamSib, did you manage to resolve this recursive load balancing with LTE?
new ways of creating vlan, probably MikroTik give us new way of vlan of few of them in new ros7.I note that the Mangle video appears to be six years old. Is there anything newer in this space for Mikrotik?
