Since it was my first time with a mikrotik i made some mistakes with the config and ended up with multiple factory resets however since yesterday the router doesn't reteurn to factory reset.
- What is did was an reset config > no defaults > load the "export verbose" script from earlyer that day.
after 5 minutes the device was not reteurned to its previouse state.
power off
pres and hold the button
restore (usb) power until the USR led starts flashing
release the button and wait for another minute
i tried multiple time also with other reset lengths
found somewhere the 30,30,30 reset. where you need to hold it for 30 seconds / power off 30 secondends / power on 30 seconds release the button.
also the netinstall isn't working
- set pc ip to192.168.88.254/24
start netinstall
select net boot and set ip to 192.168.88.3
direct connect the router to the pc with a known working cabel (also tried another)
