GreaterTX
Mikrotik Blocking Remote Access Randomly
Thu Oct 15, 2020 12:34 am
So for some reason the Mikrotik Router seems to randomly be blocking remote access to some port forwarded devices. It'll work just fine for days on end sometimes then abruptly drop any incoming connections.
This happens both with;
1) Camera system with remote web / remote app ability
2) Unifi Access Points stop communicating with the off-site controller and show as offline (But there is no firewall configuration that needs to be done on the remote site where the Mikrotik is, so not sure how this relates but this also happens while the camera system goes offline)
The network works completely normally on the LAN side, when I go on site I can get on the internet with everything just fine, use wireless access etc...
I'm running 6.47.4
How I have it setup;
Firewall > NAT I have a DST_NAT action with donate for the chain, the destination address is the WAN IP, protocol TCP Destination Port is the port to be forwarded
I've checked both
https://www.balticnetworkstraining.com/ ... orwarding/
and
Port mapping/forwarding
If you would like to direct requests for a certain port to an internal machine (sometimes called opening a port, port mapping), you can do it like this:
/ip firewall nat add chain=dstnat dst-port=1234 action=dst-nat protocol=tcp to-address=192.168.1.1 to-port=1234
https://wiki.mikrotik.com/wiki/Manual:I ... forwarding
Neither variant seems to resolve it, rebooting the router doesn't change anything.
Abruptly all of the sudden it'll eventually start working again....
What gives? What else can I provide to help you guys diagnose it
I can remotely access the router with zero issue with the configuration I have so I know that works.
GreaterTX
Re: Mikrotik Blocking Remote Access Randomly
Thu Oct 15, 2020 8:33 pm
So once again out of nowhere at around the same time after no matter how many modifications I made with no success.... it randomly started allowing traffic again at night, then this morning at roughly the same time it started blocking it again
This is freaking infuriating
anav
Thu Oct 15, 2020 9:54 pm
Post your entire config
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
MTUNA Certified, by the Ascerbic Llama!
GreaterTX
Thu Oct 15, 2020 11:42 pm
# oct/15/2020 13:39:09 by RouterOS 6.47.4
# software id = WY2W-HYQH
# model = RouterBOARD 941-2nD
# serial number = 8B1008860D52
add admin-mac=CC:2D:E0:79:D5:02 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=0 band=2ghz-b/g/n channel-width=\
    20/40mhz-XX country="united states" disabled=no distance=indoors \
    frequency=auto frequency-mode=manual-txpower mode=ap-bridge ssid=\
    SFP-Mikrotik station-roaming=enabled wireless-protocol=802.11
/interface l2tp-server
add name=l2tp-in1 user=""
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
    dynamic-keys supplicant-identity=MikroTik
add name=dhcp ranges=10.192.0.200-10.192.0.230
add name=vpn-pool ranges=10.192.100.100-10.192.100.110
add address-pool=dhcp disabled=no interface=bridge name=defconf
/ppp profile
add local-address=10.192.100.1 name="VPN IPSec" remote-address=vpn-pool
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
    sword,web,sniff,sensitive,api,romon,dude,tikapp"
/interface l2tp-server server
set default-profile="VPN IPSec" enabled=yes use-ipsec=yes
add address=10.192.0.1/24 comment=defconf interface=ether2 network=10.192.0.0
add address=WANIP97/29 interface=ether1 network=WANIP96
/ip dhcp-client
add address=10.192.0.0/24 comment=defconf gateway=10.192.0.1 netmask=24
set allow-remote-requests=yes servers=1.1.1.1,1.0.0.1
/ip dns static
add address=10.192.0.1 name=router.lan
add action=accept chain=input disabled=yes dst-port=8291 protocol=tcp
add action=accept chain=input dst-port=80,443,8291 protocol=tcp
add action=accept chain=input in-interface-list=WAN protocol=ipsec-esp
add action=accept chain=input dst-port=500,1701,4500 in-interface=ether1 \
    protocol=udp src-address-list=""
    established,related,untracked
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    invalid
    in-interface-list=!LAN
    connection-state=invalid
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
add action=accept chain=forward connection-state=established,related
add action=dst-nat chain=dstnat dst-port=36700 in-interface=ether1 protocol=\
    tcp to-addresses=10.192.0.8 to-ports=36700
add action=dst-nat chain=dstnat dst-port=5201 in-interface=ether1 protocol=\
    tcp to-addresses=10.192.0.216 to-ports=5201
add action=dst-nat chain=dstnat comment="Hikvision Client" dst-address=\
    WANIP97 dst-port=8000 protocol=tcp to-addresses=10.192.0.8 \
    to-ports=8000
add distance=1 gateway=WANIP102
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/ppp secret
add name=edrick profile="VPN IPSec" service=l2tp
/system clock
set time-zone-name=America/Los_Angeles
/tool mac-server
/tool mac-server mac-winbox
anav
Fri Oct 16, 2020 2:24 am
(1) I find it confusing you have the bridge handing out DHCP and you have ethernet 2 part of the bridge, but look at your ip address!!!,,,,,,,,,,,
I would guess that that should be bridge not ether2
add address=10.192.0.1/24 comment=defconf interface=bridge network=10.192.0.0
(2) As far as firewall rules go you have some weird ones in the input chain.......
However I am not an expert on VPN so I will assume they are fine.
For clarity sake I would put all the input chain rules first and then display the forward chain rules.
GreaterTX
Fri Oct 16, 2020 10:03 am
I’ll check out what you say
Just an update with no changes on my part the camera system and access points are back online in unifi controller
I suspect once again tomorrow around the same time they’ll be off again, but not at the exact time just roughy and with no interruption to LAN traffic (cameras still record and WiFi clients can still connect to the internet)
But remote connectivity blocked, other than winbox / direct access to the router via web those work
GreaterTX
Mon Oct 19, 2020 9:18 am
As you can see it continues to go offline at roughly the same time every day
Any additional suggestions
Users browsing this forum: robsgax and 38 guests
