Zhurik
Can't add cap lite to capsman
Sat Oct 17, 2020 2:16 pm
So I recently decided to use hex poe as my main router and cap lite as wifi access point. I tried to configure capsman but I get "no supported channel" error on my cap lite. What can I do about it?
Cap lite config:
# oct/17/2020 14:11:59 by RouterOS 6.47.4
# software id = KKFJ-ABWJ
# model = RBcAPL-2nD
# serial number = CF2F0C78F964
add admin-mac=48:8F:5A:92:34:A0 auto-mac=no comment=defconf name=bridgeLocal
/interface wireless
# managed by CAPsMAN
set [ find default-name=wlan1 ] ssid=MikroTik
add name=WAN
add name=LAN
/ip hotspot profile
add bridge=bridgeLocal comment=defconf interface=ether1
add bridge=bridgeLocal interface=wlan1
add interface=ether1 list=WAN
add interface=wlan1 list=LAN
/interface wireless cap
set bridge=bridgeLocal discovery-interfaces=bridgeLocal enabled=yes \
interfaces=wlan1
/ip dhcp-client
add comment=defconf disabled=no interface=bridgeLocal
/system clock
set time-zone-name=Europe/Moscow
hex poe config:
# oct/17/2020 14:12:59 by RouterOS 6.47.4
# software id = 72KN-XDB9
# model = RB960PGS
# serial number = D52F0C58CC9B
/caps-man channel
add band=2ghz-b/g/n control-channel-width=20mhz frequency=2437 name=\
Channel-2.4 secondary-frequency=2462 tx-power=17
add admin-mac=48:8F:5A:72:8B:49 auto-mac=no comment=defconf name=bridgeLocal
set [ find default-name=ether1 ] mac-address=88:D7:F6:BA:C7:B4
/caps-man datapath
add bridge=bridgeLocal client-to-client-forwarding=yes local-forwarding=yes \
name=datapath1
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm name=security1
/caps-man configuration
add channel=Channel-2.4 country=russia3 datapath=datapath1 distance=dynamic \
hw-protection-mode=rts-cts installation=any mode=ap name=cfg1 rx-chains=\
0,1,2 security=security1 ssid=Zhurki tx-chains=0,1,2
add name=WAN
add name=LAN
/ip hotspot profile
add name=dhcp ranges=192.168.88.3-192.168.88.254
add address-pool=dhcp disabled=no interface=bridgeLocal name=dhcp1
/caps-man manager
set enabled=yes
/caps-man provisioning
add action=create-dynamic-enabled hw-supported-modes=gn master-configuration=\
cfg1 name-format=prefix-identity name-prefix=2G
add bridge=bridgeLocal comment=defconf disabled=yes interface=ether1
add bridge=bridgeLocal comment=defconf interface=ether2
add bridge=bridgeLocal comment=defconf interface=ether3
add bridge=bridgeLocal comment=defconf interface=ether4
add bridge=bridgeLocal comment=defconf interface=ether5
add bridge=bridgeLocal comment=defconf interface=sfp1
add interface=bridgeLocal list=LAN
add address=192.168.88.1/24 interface=ether2 network=192.168.88.0
/ip dhcp-client
add disabled=no interface=ether1
add address=192.168.88.0/24 gateway=192.168.88.1 netmask=24
/system clock
Users browsing this forum: No registered users and 48 guests
