saludos comunidad, escribo para ver si alguien puede ayudarme con dicho problema que tengo, ya tengo establecido mi tunel vpn y deseo hacer telnet desde mi lan local a la lan remota , que regla deberia probar para que me que funcione dicha conexion dado que no logro hacer que haga telnet en la red remota
Greetings community, I am writing to see if someone can help me with this problem that I have, I already have my vpn tunnel established and I want to telnet from my local lan to the remote lan, which rule should I try so that said connection works since I can't make it telnet to the remote network
