VRB
Routes Issue
Tue Nov 03, 2020 2:43 am
I have set-up a VPN connection through the Mikrotik router and there are sporadic instances after settings change (like router name and password) or periods of inactivity (two days) where I cannot access any website. The issue appears to be in the IP –> Routes section wherein the connection to the VPN server becomes disabled and I need to re-enable it manually in order to operate.
Any ideas what may be causing this and how I can prevent this from happening again? This problem is causing a critical performance issue for me.
Thank you.
Users browsing this forum: CosmosNetwork, didis81, epjvdpalen, Moba, r00t and 65 guests
