orozco404
Upnp not working for open NAT o Destiny 2
Tue Nov 03, 2020 7:49 am
I play destiny 2 on steam platform, I already set UPNP on Winbox to get "open NAT", but it is always "moderate NAT", I have so many problems playing multiplayer. Game is setting DaemonWarePortMaping but it is not opening ports, The bytes and packets counters are Always 0, it looks like it is not working. I have defaults config. [Image atached]
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=ether1 type=external
add interface=bridge type=internal
Thanks for any help!
anav
Re: Upnp not working for open NAT o Destiny 2
Tue Nov 03, 2020 6:22 pm
Should work fine without UPNP?
Do you have a public IP address?
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
MTUNA Certified, by the Ascerbic Llama!
DarkNate
Wed Nov 04, 2020 12:11 am
Your ISP puts you behind a CGNAT and they've not implement port control protocol.
orozco404
Wed Feb 17, 2021 2:02 am
Thanks, you're right. my ISP use CGNAT
Users browsing this forum: ak4020, Joe1962, uiblogit and 64 guests
